Fs: My R32 Skyline With R34 Neo Engine
  • Replies 62
Posted Images
  • 1 month later...
Very smart conversion.I like it.But You should put XR6 turbo on it=400hp
You really have NO idea, do you??? :rolleyes:
Congratulations!! (regarding the baby)
Good Luck with the sale. If i didn't spend so much money on my 33 i would have flown up for a serious inspection. R32 with an RB25 NEO is the ultimate :( !
Guest Miss_Nismo
Sup,
If it is available in 2 weeks, i will offer you that. Hope it still is.
I will still be trying my damndest to sell this car in the meantime unless a deposit is offered.
But, yes if we have been unsuccesuful before you are ready, you are welcome to take it at that price.
We tried fitting the baby capsule, but the rear seat is too small. Hence the baby doesnt get to leave the house until a new ar comes.
Edited by Miss_Nismo
Guest Miss_Nismo
You really have NO idea, do you???  :D
Good Luck with the sale.  If i didn't spend so much money on my 33 i would have flown up for a serious inspection.  R32 with an RB25 NEO is the ultimate  :D !
It really is a serious car, deserving serious inspection. We saw a very similar 32 with same paint (out of a spray can by the look of the quality finish) go for high -teens with the rb20 still in place.
This engine comes on to boost hard and strong (dual stage removed from the solenoid) but is also VERY quiet.
Cheers,
For your sake I hope it goes :D But for mine I hope it stays. I went back to the photos today and didn't notice the engine and interior photos were taken in '02. Do you have any recent ones as I am in WA and wont be able to inspect the vehicle due to a extremely heavy work load.
Does the car have a turbo timer? I dont see any mention of it.
Edited by Tofu
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
