Fs: My R32 Skyline With R34 Neo Engine
  • Replies 62
Posted Images
  • 1 month later...
Very smart conversion.I like it.But You should put XR6 turbo on it=400hp
You really have NO idea, do you??? :rolleyes:
Congratulations!! (regarding the baby)
Good Luck with the sale. If i didn't spend so much money on my 33 i would have flown up for a serious inspection. R32 with an RB25 NEO is the ultimate :( !
Guest Miss_Nismo
Sup,
If it is available in 2 weeks, i will offer you that. Hope it still is.
I will still be trying my damndest to sell this car in the meantime unless a deposit is offered.
But, yes if we have been unsuccesuful before you are ready, you are welcome to take it at that price.
We tried fitting the baby capsule, but the rear seat is too small. Hence the baby doesnt get to leave the house until a new ar comes.
Edited by Miss_Nismo
Guest Miss_Nismo
You really have NO idea, do you???  :D
Good Luck with the sale.  If i didn't spend so much money on my 33 i would have flown up for a serious inspection.  R32 with an RB25 NEO is the ultimate  :D !
It really is a serious car, deserving serious inspection. We saw a very similar 32 with same paint (out of a spray can by the look of the quality finish) go for high -teens with the rb20 still in place.
This engine comes on to boost hard and strong (dual stage removed from the solenoid) but is also VERY quiet.
Cheers,
For your sake I hope it goes :D But for mine I hope it stays. I went back to the photos today and didn't notice the engine and interior photos were taken in '02. Do you have any recent ones as I am in WA and wont be able to inspect the vehicle due to a extremely heavy work load.
Does the car have a turbo timer? I dont see any mention of it.
Edited by Tofu
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
