hey guys, put my skyline in to get tuned today and there seem to be a code to unlock the computer to tune it. I've bought the car second hand so i dont have the code and the previous owner doesnt have the code as he never recieved one. Does anyone know where to get the code? Because otherwise my only option is to send it back to japan to get reset. any help would be appreicated
https://www.sau.com.au/forums/topic/83605-power-fc/
