Guys;
just bought these HKS dumps (has HKS cast into them) supposedly for a GTR. no way the exh housing bolt pattern will line up to my N1 turbos although the casting is the right shape ie round on one side and angular on the other etc. if you know them you know what i mean.
was there a 'way back when' change of turbo exh housing flange patterns maybe? as far as i know garrett/HKS/nissan use the same exh housing / dump bolt pattern.
any ideas?
cheers
https://www.sau.com.au/forums/topic/83654-hks-cast-dumps-for-gtr/
Guys;
any ideas?
cheers
Definitely not for a GTR :rolleyes:
These are what GTR dumps look like..well MINES ones anyway. notice one is longer than the other
Guys;
any ideas?
cheers
They are to suit a very early version (non ball bearing) of the HKS 25/??. This version had a different exhaust flange, and therefore the terbs were sold complete with manifolds in order to make the terbs a bolt in unit.
Thanks guys
300zx is looking good acording to GCG and BD4s. Garrett has asked me to do some measurements. interestingly the bolt pattern corresponds to 300zx exh housing and part numbers are 065L and 064R which leads me to think it's a v config engine.
Gav it's possible but they could only be off GTR/2JZ/Z32/1JZ/EJ20TT and they all came out in the late 80s/90 and newer. I didn't think the bolt pattern changed for any of these from new ie I think the original bolt patterns remained and these were the ones used by HKS.
Regards
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
