Hey guys,
Ever since I have had my car I have noticed a noise thats quite audible from the engine bay.
Its hard to describe but its like a constant high pitched scratching that goes up and down in tones.
Anyway my mates dad reckons its because the timing belt (recently changed) is either too tight or too loose...cant remember which one :D
Basically just want to know if either of those factors result in such a noise & if so, is it something I should get fixed...cos my friends dad reckons it will go away over time (about 5000kms on the belt so far).
The belt is a genuine nissan product (part #13028-5L327) & the car is a pretty stock standard R33 GTST.
Any input would be great! Thanks!
https://www.sau.com.au/forums/topic/83668-noise-from-engine-bay-timing-belt/
yeah same thing happened with me actually, after i got my car back from getting a new timing belt there was a squeeling noise coming from my engine bay and its still there after 5000kms :|
although mine is a 32 and i used a greddy strengthened timing belt, it seems ive got the same problem. might not be the timing belt but one of the other belts they took off to get to the timing belt. unfortunately getting a mechanic to investigate may be costly!
eager to hear other ppls thoughts
Try squirting either a little water, dishwashing detergent or WD40 onto the timing belt. If the noise goes away, you've identified which one is causing the problem.
I've found WD40 the best because of the long nozzle. You can squirt a tiny bit on without making a great big mess. I guess you could always put some on before you start the motor?
i can't believe you guys put up with it for 5000kms!!!
FTR i changed my timing belt when i imported my car. it makes NO noises. so no it's not normal for a new timing belt to make a scratching noise.
I'd put my money on the timing belt being too tight: its quite a common mistake. According to SK's guide, there should be about "5mm in and out (ie; 10 mm total movement) using one finger".
I really must get my changed soon (peace of mind, etc). Richard: did you get Nath to change it? Any idea of the rough cost?
Lucien.
Theres a good chance that its the tensioner bearings, are you sure the noise is coming from the timing belt area?
If you can you could try disconnecting the air con belt to eliminate that as a cause. And try disconnecting the other belts and seeing how the alternator and water pump bearing feel, they should not feel rough or rumbly...
IN regard to tensioners, there are two down there, they could be showing their wear more now that the new belt is tight and putting more pressure against the tensioners. They will make a squealing type sound if worn. There are two, priced around $75 each, they should always be checked for wear when you replace a timing belt. Unfortunately the labour is going to cost around the same as fitting a belt as you have to remove the belt to do it.
P.S. make sure you check this properly, they say that the bolts that hold the tensioners have a habit of breaking - causing very bad things to happen to your engine - and the only way I could see this happening is if the tensioners seize or something.
im taking my car back to the place i got it done, coz aparantly they often need to make small adjustments after fitting it to get the tension just right... its getting looked at on tues so ill let u guys know how it goes! lucky for me its not gonna cost nething coz its just fixing the problem they created :D
well i am madder than a cut snake... dont mind me always wanted to use that line! theres nothing wrong with my timing belt aparantly, its just the fact that its the greddy strengthened one... according to the performance shop they tend to make noise. not happy considering i spent $170 getting them to check it out and basically reinstall it! but yeah ur looking at 2-3 hrs labour and the initial cost of the belt ppl... the final cost depends on ur mechanic and whether u go for a stock belt or a strengthened one. strengthened ones set ya back over $150. unfortunately my belt is doomed to a life of squeeking
This doesn't sound right to me.
If they "knew" they always made that sound, why exactly did they pull it apart to check it out? They should have known straight up what that sound was.
I don't understand how a different belt type can cause a squeaking anyway, unless it's a different size possibly? But either way, it's just stronger...
I also just had timing belt changed. Used the Greddy strenghtened one also. It 2 makes a squeking noise, a little like a mozzie is under the hood. Guys where i got it done said it's normal. One has it on his new 34 gtt and makes exact same noise. There is nothing wrong with it, just have to put up with it for a while
yeah im kinda thinking the good olde nissan one might have been a wiser choice, seeing as im not doing nethin insane with the engine. and in response to what u said TommO, they tried telling me that it wasnt the timing belt to start off with, which i knew was wrong so i told them to check the timing belt. after 3 hrs labour they finally tell me it actually is the belt and theres nothing they can do. i suppose the sound isnt too bad and when i get my full exhaust itll mask the sound good. im just annoyed about the money! oh well ill live ;)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
