Power Steering Noises......
Heya all....
From being cold, i'm getting quite a bit of 'whirring' noise on startup, and have since worked out that the noise is from the power steering.....
It's rather noisy when cold, and does disappear after the car has warmed up.
(Move steering wheel, more noise, almost like you hear on some cars when you push full lock)
I have noticed that there is some fluid on the outside of the pipe leading to the steering rack (where the steering wheel rack joins) and some more leakage on the join from the resevoir.
Is this the pump failing, or is there a belt etc that needs to be replaced?
regards,
Zeb
Mate,
There is likely to be air in the power steering system due to the leaks. In the short term simply bleeding the power steering system will reduce or fix the noises completely.
In the long term you should fix up the leaks or if the pump is buggered then service it or get a replacement.
Good luck.
Oh...and to bleed the system. Take the cap off the power steering resevior and turn the car on. Move the steering from full lock to lock and look for bubbles escaping to the top of the power steering fluid. Refill as needed while doing this and do about 20 turns from left to right or until no sounds or bubbles are produced.
Hi mate,
Just had the exact same problems, fix the leaks first before u bleed its prolly just some loose clamps, thats the exact hoses that were lose on my, I put new hose clamps on tightened them up nicely and bled the system. Now no more leaks at all and no squeal.
Turning the car on and turning it from lock to lock isnt really a great way to bleed the power steering system.
The best way to do it is remove the powersteering belt and manually turn the power steering pully while the car is turned off. Do this for about 3 minutes and it will be completely bled. After that go and do some figure eights lock to lock if needed.
But make sure you fix the leak before doing this.
Cheers
Turning lock-to-lock is the way to bleed it, but first raise the front of the vehicle on stands. Doing this with tyres on the ground, vehicle stationary is a great way to kill the PS pump. Nigel is spot on check the hose clamps at the base of the reservoir, they tend to come loose on their own, it happenend to me with both skylines.
Update for people, it was air in the the system, I only needed to in put a *tiny* bit of fluid in whilst bleeding/forcing the air out.
( less than 5% of the bottle, if that )
NigelS : That's exatly what I found, loose clamps on the resevior now fixed thanks!
Thanks for all the replies - for the ammount of noise it made, very little fluid and effort to fix!
(I moved the car to a nice sandy area nearby, to reduce wear&tear, as no stands to hand... when moving the steering etc.)
Sambo33 : The fluid did look dirty - Next oil changed, will be changing the fluid too.
Fat32 : Thanks for the pm's too.
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
