hey guys, is there a difference between an actual manual and a tiptronic manual ? besides the obvious(no clutch, shifts up down etc). do they both work just as well ?
also, would the gear ratio change when u shift it over to semi-manual ? or will the ratio be exactly the same as if it was crusing in auto ?
https://www.sau.com.au/forums/topic/83729-tiptronic-question/
a manual is better, a tiptronic is 1/2 way as good as a manual from a normal auto IMHO
its good also being on boost (albiet lesser) when changing also, at least thats what it feels like.
its bad that there is a gap in the changes but this can be remedied with a shift kit so I have read on here.
and yes Bob u were right once I got used to the steering wheel shifts I find them better than the paddle, not a wank at all.
Being that equivalent manuals cost at least $5k more a tiptronic is not a bad option IMHO.
Just from my experiences
tipronic = auto
SMG = hydraulis actuated (proper manual with no third pedal)
DSG = electronically dual clutch system manual from Audi-Porsche
F1 = Ferrari is similar to above but is single plates and is very twitchy and sometime down right rude and aggresive, think of spinning wheels at lights take of on small accelerator openings.
Off all the above the SMG is the most problematic, my last M3 is REALLY my last M3, as for the F1 until you try it, you really never know what you're missing out on.
I drive a Mitsubishi FTO with Tiptronic transmission.
Most people don't understand exactly what it is Tiptronic is.....it is a totally automatic gearbox.
Untill you push the shift lever over into sports mode at which point the car becomes manual.....so to speak. You can take the car to redline and it will bounce off the rev limiter untill you change it (this may vary from model to model as I hear the XR's automatically change up if you bounce off the limiter) The car will not change gear untill you tell it to.
Disadvantages of tiptronics are that you can't really launch the car....unless you got your foot on the break to hold you there. Some people also tend to think that there is massive delay in between shifts....there isn't really, we're talking milliseconds here people.
Another disadvantage is that they're freakin expensive if they break!
Considering tiptronics are generally cheaper than manuals.....I say go for it......you can have just as much fun as manual but push it back into auto if you just wanna chill in traffic.
cheers mate. nice info.
one more question. how do know what gear you're in ? say u're crusing in 4th gear and approach a traffic light(red), do u push the shift stick down 3 times(4-3-2-1) ? or push it up once to get it bak to 1 (4-1) ?
thnx every1 else.
You need to either push the paddle on the steering wheel 3 times to get it from 4th to first, or move the gear stick 3 times to get it from 4th to first.
That is the one downside.
Also, another thing that I've noticed is that you can down shift on demand, but you cannot up shift on demand (particaularly going from 3rd to 4th). You need to be at a certain speed or RPM (not sure which one) before you are "allowed" to shift.
I believe the SHIFT KIT fixes this slight problem.
oh okies, cool.
Not sure about the R34 but the tiptronic FTO has a gear indicator on the speedo so that when you're in tip mode you can just look at the speedo to see what gear you're in.
And when it comes to stopping....you can downshift to 1st if you want or you can just roll to a stop and the car will automatically shift down to 1st once the RPM's are low enough.
ya GTT is the same, number on speedo, definately shifts down from 2nd to 1st by itself not sure about the rest of the downshifts yet.
lol, i thought there was something wrong with the tranny when i couldn't change from 3rd to 4th. Even happened on the same stretch of road twice and i didn't figure it out.
Yeah same dude... I was driving at 40kmh and full trying to get the gears up. I just sat there pushing and pushing the gear stick but nothing. Got kinda worried up until i figured it out :)
Yeah same dude... I was driving at 40kmh and full trying to get the gears up.  I just sat there pushing and pushing the gear stick but nothing.  Got kinda worried up until i figured it out :P
the only tiptronic i've driven is my dads BA...and it sounds the same as your skylines and FTO's
with the fords, when you push the stick over to the left (and dont move it up or down) it goes into performance mode, which is the same as the "power" and "econ" switch on the older ford autos and holdens too... it is still fully auto, but will rev higher than when its in normal auto mode.
then if you move the stick up or down, it will go into tiptronic and you have to do the changing...you can bounce off the limiter, and it'll hold the gear. the only time it really changes a gear itself, is if say for example you approach a red light in 4th, and dont gear down, when the car gets to about 20km/h it'll drop straight into first, and you cant engage second until you're over 20km/h
definitely good fun...as others said, its half way between an auto and a manual...
Most Tiptronics are just autos with a tarted up shift gate. Most of the Euro cars will not hold gear at redline (a scary prospect when you're barrelling towards a hairpin in a rented Boxster and the f**king things upshifts on you and surges forward past your comfortable braking point.....)
Some are better than others, and they will hold whatever gear you put them in, but that's not an inherently Tiptronic function. The old Mazda autos had a "hold" button (but no fancy paddles or toggles), and it held the car in whatever gear the shifter was in. So if I put it in 2 with the hold button at a set of lights, it'd take off in 2nd gear. And if I used the stick, it would change pretty much then and their.
In the end, that's a programming feature rather than an inherent engineering advantage.
After driving a couple of Tiptronic-equipped cars, I wouldn't buy them thinking they're a good compromise between a manual and "auto". They still have all the problems of an automatic, but with the problem that you expect more from it and so it frustrates you more when it acts stupid.
The Tiptronics don't necessarily kick down immediately (the Boxster's needs 2 presses and a little bit of time to drop from 3rd to 2nd, but it'll upchange as quick as the technology will let it) and they still have the same torque converter losses that your regular slushbox have.
If you can get a true clutchless manual then that's great (since they're a true clutch gearbox, but hydraulically actuated), but the cheapest car after the Alfas to have them is the BMW M3 SMG. After that, you're talking about Aston Martins, Ferraris and Lamborghinis.
The DSG gearbox would be great too, but only VW has them so far. Those things have two driveshafts and a clutch for each pair of gears, so as you change gears it disengages one clutch and engages the next. Seamless power...
Being able to control gear changes is a good compromise to me.
No such problems with mine, it has never acted "stupid". Good compromise between auto and manual functions so far.
Another thing I would like to ask is, Once you go into that triptronic mode, does it chu petrol like crazy???
personally i think it can be used to go either way.
when i use it in my dads BA, its coz i want to have a bit of fun...so i let the revs go higher then change etc....quicker take offs etc
but if you put it in tiptronic, you can put it in 4th earlier, and take off slower , keeping the revs low as.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
