this is for my close friend
1995 Mitsubishi FTO GPX
Custom pearl blue respray
17" S2 chromes
5zig exhaust
boomerang alarm
mdlp HU
tinted windows
full v'side kit
lowered
retrimmed interior
neons n ricey stuff
apexi afc
mivec controller
ring 0403 315 368 for more details.
$26,000
I've been in this car and its very nice, interiors been fully re-trimmed matching blue and black and the sound system is very good.
Pics:
Car is in Melbourne btw.
https://www.sau.com.au/forums/topic/8374-fs-95-mitsubishi-fto-gpx/
tell him i'll give him 18max :D
i can get a 94 model for 14k
PS. is the kit actually have VEILSIDE stamped into it or not?
but seriously this is probably the wrong forum.... unless someones going to get one for their GF lol
18 is a bit low for this specimen
it has full electrics
md head unit with speakers and subbie in the boot
and this paint color is unique
the head lights have also been changed
im not too sure about the veilside stamp thing
dude i can get one imported with mods already for 14k and do all the rest and maybe even turbo it with the money saved lol
hope the sale goes well tho :D
EDIT**
i might know a chick that will want it...
will get back to u
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
