oi i was gonna say the blitz sbc id3
or u can also go the hks evc iv
seriously, go look at the information for all of the mentioned boost controllers, then see which one suits u, and u like the look of, depending on price also, u can also get the ricey sbc color.
meh.
meh.
so u reckon they are better that avc-r or profec - e?
What about the Hybrid 2-stage electronic boost control?
Has anyone got anything good to say about that little gadget? I bought one simply because it was a good 'cheap' price for a EBC.
Brendan
Yeah and despite those features they are still a pain in the ass to use and still dont hold boost better than a decent bleeder IMO!!! Go the Blitz...
...i no longer use an AVC-R, but did for 3-4 years with both the std turbo and a Trust turbo. The thing worked extremely well, never spiked, held stable boost. I was vert happy with it.
There have been several instances where ppl claim they have not worked...i just cannot understand how this can be the case. If you understand how they work (which aint rocket science, just read the manual) then they are even easy to setup. The instances where they have not worked 100% have usually been traced back to not being installed correctly, with wrong diameter hose, undesirably long lengths of the incorrect diam hose etc, its debatable whether any EBC woudl work optimally if installed in the same manner?!?!?!?!?!?!?
And they are a very flexible EBC, and the variabel duty cycle works very well as my std wastegate presssure is 0.65bar, and with the AVC-R set to 1.25bar it held boost just fine. So thats 9psi to 18psi and it managed to control boost. Others seem to say that its very difficult for an EBC to increase boost so much beyond what std spring pressure is, AVC-R did it.
Who gives a shit about a gain function when there is a PID loop trimming the boost to the desired level. This is how the autronic boost controller tables work and it is well impressive.
What you really want is a boost MAP, RPM vs Load just like any fuel or timing MAP. This way you can eliminate the wastegate cracking to early.
I dont think you can compare a bleeder vavle to a ebc. ie if your wastegate spring tension is 8psi and you want to run 15-20psi how is a bleeder going to hold the boost further along in the rev range when more and more pressure needs to be bled from the actuator?
If only everything was linear eh..
    • btw... here's a fun quote I got back in the day (using a NEO head and going shimless): a bit different initial requirement
    • You can definitely do 450kW on the RB25 non-NEO head, plenty have. The $600 to $800 conversion will end up costing you much more I suspect, I believe you will require machining. NEO head has the lowest barrier to entry.   My 2c?  buy a BMW 😆
    • No more 90s JDMs for me, just want 4 door cars that won't attract cops. Wouldn't mind a Hako or a 240Z all motor but modernised (big comp, big cams, ABS, DBW, dis dat).
    • The reason I made this thread was to try to get some useful info as all of the older threads only have tidbits here and there, while I do appreciate banter and suggestions of shoe horning V8s into cars, for the sake of someone trying to make a decision on this topic - is the general consensus that you really don't need to convert to solid lifters unless you're chasing wild above average power and rpms? options -  Stick with hydro lifters possibly make 450kw at 7500rpms assuming all the right supporting mods for that goal Spend the $600-800 for the Solid lifters and find out how hard it is to set the clearances and what else needs replacing around them Neo head - possibly will cost more depending on the head prices at the time Throw away RB or buy a BMW 😆 There's a lot of the solid kits getting around from different manufacturers so someone must be doing the conversion
