oi i was gonna say the blitz sbc id3
or u can also go the hks evc iv
seriously, go look at the information for all of the mentioned boost controllers, then see which one suits u, and u like the look of, depending on price also, u can also get the ricey sbc color.
meh.
meh.
so u reckon they are better that avc-r or profec - e?
What about the Hybrid 2-stage electronic boost control?
Has anyone got anything good to say about that little gadget? I bought one simply because it was a good 'cheap' price for a EBC.
Brendan
Yeah and despite those features they are still a pain in the ass to use and still dont hold boost better than a decent bleeder IMO!!! Go the Blitz...
...i no longer use an AVC-R, but did for 3-4 years with both the std turbo and a Trust turbo. The thing worked extremely well, never spiked, held stable boost. I was vert happy with it.
There have been several instances where ppl claim they have not worked...i just cannot understand how this can be the case. If you understand how they work (which aint rocket science, just read the manual) then they are even easy to setup. The instances where they have not worked 100% have usually been traced back to not being installed correctly, with wrong diameter hose, undesirably long lengths of the incorrect diam hose etc, its debatable whether any EBC woudl work optimally if installed in the same manner?!?!?!?!?!?!?
And they are a very flexible EBC, and the variabel duty cycle works very well as my std wastegate presssure is 0.65bar, and with the AVC-R set to 1.25bar it held boost just fine. So thats 9psi to 18psi and it managed to control boost. Others seem to say that its very difficult for an EBC to increase boost so much beyond what std spring pressure is, AVC-R did it.
Who gives a shit about a gain function when there is a PID loop trimming the boost to the desired level. This is how the autronic boost controller tables work and it is well impressive.
What you really want is a boost MAP, RPM vs Load just like any fuel or timing MAP. This way you can eliminate the wastegate cracking to early.
I dont think you can compare a bleeder vavle to a ebc. ie if your wastegate spring tension is 8psi and you want to run 15-20psi how is a bleeder going to hold the boost further along in the rev range when more and more pressure needs to be bled from the actuator?
If only everything was linear eh..
    • Thank god. I thought I was the only one, nobody seems to mention this (cause nobody really goes this far in Sedan land). The car's track is 10mm wider at the rear, which explains why the rears sit a little further out for the same size wheels. There's not really many options in widebody land for sedans anyway - People will just use whatever came out of the box and then buy wheels/spacers to suit. To get it perfect you'll likely need custom wheels with custom offsets if you really want to get it perfect which is what I plan to do, but I also plan to utilize more of the inboard space for tyres at the rear... which is also something nobody ever seems to do.... OR my maths have failed me after 20,000 attempts and I'm about to make huge mistakes.
    • What colour is that?  A mate of mine went red/black on his SLR5000 tribute recently also.  And yes, also glad to see this still progressing albeit slowly.
    • found a company that makes a flat gauge face 3-d printed mounting base kit to eliminate the dished style gauges. if anyone else is looking to do the same https://www.dashfreaks.de/shop/flat-dials-holder-nissan-skyline-r34-gt-gtt/
    • I installed my link ecu shortly after. But car ran fine with stock ecu and r35 coils, just had the traction control and slip lights on.
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
