R32 GTR Gearbox $500
R32 GTR Fuel Pump $200
R32 GTR Rear Cradle $150
R32 GTR Rear Bar Suppourt $100
R32 GTR Radiator $150
R32 GTR Clutch x2 $100 each
R32 GTR Rear Wing $200
R32 GTR Rear Steering Rack $100
R32 Cat Back Exhaust $400 with stock front pipes
R32 GTR Turbos $400 pair
R32 GTR Standard ECU $100
R32 GTR ARC Airbox $150 (needs a good clean and filters)
R32 GTR Cam Gears $100 pair
R32 GTR Sump/Diff $200 from blown engine
R32 GTR Intecooler $150
R33 GTS Series 2 Wing $100
R33 GTR AFM x2 $200
R33 GTR Air Con Condensor $200
R33 GTR Fuel Tank $150
R33 GTR Clutch $150
R33 GTR Rear Bar Suppourt $200
Trust oil cooler with lines and adapter $500ono
Q45 AFM and Plug $250
Parts are located in sydney willing to freight at buyers cost
[email protected]
https://www.sau.com.au/forums/topic/83751-left-over-gtr-parts/
Hey, pretty keen on a few of these bits;
Whats the condition of this stuff? (Specifically the box and clutch).
Christian
Prank: The clutches are average, the gearbox is from a fire damaged car it is mechanically fine but due to heat the wirring,sensors,shifter and slave clylinder need replacing prefect if youve blown ur gtr box or want a spare. The other stuff is in good condition
Robocop: Dont have pics of the ARC airbox at the moment will post some up asap
Reece: The R33 GTS Series 2 wing is white, needs a respray
NETIME: The R32 GTR wing is charcoal and in perfect condition
GTS2-X: I will do my best i may have some other aircon pipes etc
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
