mustve been something wrong there for a ringland to go in a rb20det....what caused it, if i may ask?
Im not too sure, there was a bit of pinging involved im guessing.
Im not too sure yet if its a ring land, but its suspected, as there is alot of oil getting straight into the bore, and getting burnt up causing a bit of smoke.
My old man is ping tone deaf. :P
He held it down in his EF Fairmont some time back and it was rattling its head off. I was like aaaaahhhhhh stop.... Its pinging its head off, No wonder its blowing smoke in the revision mirror.
I can't hear it pinging he said. :)
my guess is somebody thrashed the pants off it running silly high boost and stock ecu, as seems to be all the rage these days.
you can use but you'll have to swap all the sump and things over as that has your front diff in it, whereas on RWD it doesn't.
do a search and you will find some info..
To your original question - the sumps are different between the RWD and AWD versions of the RB20DET - you can't swap sumps between the 2.
I just happen to have a RB20DET from a GTS4 sitting on the garage floor (in Melbourne). PM me if you are interested.
I had one let go, but only because it blew a water hose.
I've had a ring-land go, big time (on another RB20DET, not the one I offered you). Chunk of piston hit the end of the sparkplug and shut the gap right down, then shot peened the combustion chamber and top of the piston. Broke a ring, and bent it upwards. Engine ran on 5, sounded like a chaff cutter. Amazingly, the bore is still perfect.
And how did you's run on the 5 cylinders? Much smoke out of exhaust? Mine blows abit when u free rev it some times... the radiator israther bubbley..
Hey mate, I have a R32 GTS4 motor sitting in my garage, it has the head off of it, comes with front diff, basically consists of:
block with pistons in it
head complete
plenum
coilpack and injectors
I am in Brisbane also. I am moving interstate in a few weeks so I want it gone. I have it advertised in the forsale section but am quite neg on that price. pm me if you are interested.
Stephen
Did a comp test on the motor today, #1 is holding 50psi, which is not a very good sign, so its time for replacement pistons.
gts4diehard: Cheers buddy, but ive got a spare rb20det block sitting here, gonna replace damaged pistons, put in new rings, and bearings also.
Thanks for the help guys.... will let you's know how i got next weekend when it gets ripped apart...
PS: I moved away from mitsubishi's hoping i wouldn't have to touch motors again... little did i know.. nissans are just as bad.. hehehe..jks..
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
