Copied from a post on another forum made by my boyfriend.
Item: 1988 VL Commodore Turbo
Website: http://au.boostcruising.com/readersrides/entry/6/8784.html
Item Condition: Mechanically all good, body requires attention (no rust though!)
Reason for Selling: Buying a house
Price and Payment Conditions: $11,500.. ono.. no trades accepted, we need the cash to buy a house.
Extra Info:
1988 VL Commodore Turbo. RB30ET with T60-1 turbo, 45mm wastegate, JD Custom plenum, 600x300x75mm intercooler, SARD fuel pressure regulator, big injectors (600??? cc), 3000rpm stall trimatic conversion (fully manualised, with B&M ratchet shifter), Haltech E6K ECU, HKS pod, AVC-R boost controller, , retrimmed VN Calais interior, disc LSD rear end, slotted and cross drilled DBA "Gold" series rotors all round, Bosch 044 high pressure pump, Carter lift pump, surge tank, VX commo rims, TIGHE cams reground cam, adjustable cam gear, new stronger valve springs (thanks to WASP... :P ), metal head gasket, stronger ignition coil, brand spanker new headlights (including indicator assy) with cool bulbs, alarm and central locking, plenty of stuff Ive probably forgotten. Has run a 12.6 @ 111mph before of the latest mods, currently has around 290rwhp at PITS (Matty Spry) dyno.
We are saving madly to buy a house and as we don't really cruise around anymore and the missus has just sold the skyrice and bought a economical 4cyl, this car really needs to go to a new home that will use the power it has.
Contact Details: SAu PrivMsg, ... Happy to give my mobile to interested parties, but I dont want every tire kicker and joy rider ringing me at work.
https://www.sau.com.au/forums/topic/83768-1988-vl-commodore-turbo/
  • 1 month later...
  • 4 months later...
Bump.
hey mate i'll put ur vl for sale on a few holden forums for ya u might have a better chance selling it then.
an whoeva said that vls are guy youv got some serious problems mate australia is home to the fastest vl mate in aus an NZ. i kno a few VLs that eat skylines buddy, not only that but F#$K VLs r SEXY
Gee! Why don't you marry one! :P
jk.
Nice car though, good luck with the sale
  • 2 months later...
That is pure gold!!! hahahaha best laugh I have had today
Bump on a nice car try the commodore forums!!
Edited by Fitzpatrick Speed Works
Guest
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
