Genuine HKS SSQV Blow off valve with HKS adaptor plate for Nissan Skyline R33 RB25det. Direct replacement for standard R33 BOV (possibly for r32 and r34), no custom work needed, straight bolt on. BOV plus adaptor $330.... open for offers.
Edited by thirtythree-II
https://www.sau.com.au/forums/topic/83773-sold-hks-ssqv-bov-hks-r33-adaptor/
  • 3 weeks later...
Would u swap for anything?
