Yes, they should fit, same as for RB20DET. The Splitfire number is SF DIS-001, but I can't recall the Nissan factory number.
s.2 R33 onwards have a detail difference and the pin order on the plugs is different to account for elimination of a separate igniter box.
Check out either Nengun, or Kudos Motorsports here on the board for price/availability and model applications.
FWIW, check the search function and you will see that an easy, temporary (very temporary) fix, or method of fault finding is to remove your coils and wrap wide insulation tape around them to prevent arcing.
Firstly though, get a turps rag and wipe off any grime and soot, then get some electronics contact cleaner and spray in the connections (loom + spark plug end) to give it the best chance.
Best of luck, but when you are getting misfiring, there's a good chance its time for new coils. Nissan are not the only brand to suffer this problem - its related to the age and positioning of the components.
cheers
