Help for the searchers, alternate names.
Oxygen Sensor, Lambda Sensor, O2 sensor, A/F Ratio Sensor, Narrow and Slow A/F Ratio Sensor, Not a Fast and Wide Lambda Sensor
I figured it was time to have a dedicated Stagea lambda sensor selection, buying, wiring and fitting thread. There is a lot of info but it is spread out in a number of incomplete threads. So I hope this one will cover everything, with your help of course.
I bought a new lambda sensor from my local Repco yesterday, ACA brand part number ROX207 for an EL Falcon cost $77.97 inc GST. It has 3 wires, 2 black and 1 blue. I will cut the wires and connect it to the Nissan plug via connectors as stainless steel wires do not take solder. They are stainless steel to take the heat, copper or aluminium would simply melt.
Pictures would be here, but I can't figure out how to upload.............
:blink: cheers :)
https://www.sau.com.au/forums/topic/83819-fitting-a-new-lambda-sensor/
Hi SK,
Ive bought a Repco 'ACA ROX207' oxygen sensor to suit Ford EL. Cost $81. Has 3 wires connecting to a plug; 1 blue wire (by itself in the plug connection), and 2 black wires side by side next to the blue wire.
I hope this is the right one!
Having the Stagea serviced in a few days time (80000km), adding a small body 3inch Catco cat converter (from batmbl), a 3inch stainless single turbo to cat dump pipe (from Just Jap off ebay), a Black Widow car alarm (for insurance sake; thanks Shannons!), a Hybrid EBC (off ebay), an Apexi SAFC II (off ebay), and an R34 GTT intercooler (from member: Ed). With a K&N pod filter and Dayz Special Edition cat-back 3inch mild steel exhaust it should all run well together.
With all of the above fitted and dynoed, hopefully power increases a fair bit, and the fuel issue is 'sort of' fixed with the new O2 sensor.
Once it's all tuned I'll post up a detail of litres per 100kms. And maybe a dyno graph, if it's impressive enough!
Brendan
I cut off the Ford plug and then I checked the lambda sensor plug (three pin) on the Stagea and BINGO it is the same as the lambda sensor plug on the R32GTST. So I cut off the old R32GTST lambda sensor and then used a crimp joiner to attached the three wires, 2 X blacks to the outside pins and the 1 X blue to the inside pin.
Picture will go here when I figure out what's wrong with the upload facility.
The lambda sensor is 22mm, and I have a big 22mm ring spanner that should do the job just nicely. Remove the old lambda sensor and screw in the new one.
Then plug the new lambda sensor in,
Fill the Stagea up on the way to work tomorrow and check the fuel economy over the next week or so. I will post up before and after results
:) cheers ;)
Edited by Sydneykid
After replacing the o2, how should i go about resetting my ECU?
I am not going to bother, I don't think it makes any difference when you don't have any error codes.
You can unplug the ECU, that resets it. Or unplug the battery and stomp on the brake pedal (with the igntion switch on) a few times to make sure all the power is drained. I hate doing that as the clock looses its time and the radio looses all of it preset stations.
:) cheers ;)
For some reason, the bolt in my ECU plug has had its head snapped off.... is it time for me to dremel the bastard out (something i am not happy to think about with all those wires there...)
My guess is someone has tried to tighten the bolt up with the plug not aligned. I would drill it and use an easyout. Much neater.
SK - Do O2 sensors wear out ? Would it be good practise to change the one on my 15 YO R32 ?? Even though it seems to be running fine ?
Nissan recommends changing them every 40,000k's. They don't "wear out" in a mechanical sense. They just get contaminated and don't read the A/F ratios properly.
:P cheers :)
Edited by Sydneykid
Got my new o2 today! YAY (original nissan from jp)
Will go ahead and do the swap this weekend, saturday morning. Will do spark plugs at the same time.
Ill take photos while i do it and do a little write up for everyone...its original so its litterally screw out - screw in.
Anyway, ill post back saturday night,
Alex
Edited by AlexCim
  • Like 1
The gallery is working, so here is the picture of the Falcon lambda sensor with the R32GTST plug fitted to the wiring harness using crimp connectors.
The 7 day fuel economy test is underway, results tomorrow.
:D cheers :)
Edited by Sydneykid
Alex
How are you going getting the old one out? I tried today and gave up getting a spanner in.. I've rung around town and nobody seems to have the 'oxygen sensor socket' in stock either...
Edit: and slightly off topic, SK - How did you get the gallery working? Is there something special you have to do/be to post images there? I just went over to it, and cant find any button or menu to upload images...
Ian
Edited by ian
Over the weekend i went to try to install my new split dump and front... it ended up not fitting so on the way putting everything back, i put in the new O2...
Unfortunatly, this means i have no photos or anything, but its relativly easy to remove your dump pipe (i could probably do it now in around 1 hour)
The OTHER way around it could be like this...
1. remove engine heat sheild
2. remove the top three bolts holding in the brace, take brace off
3. undo the screws holding on the heat cover on the dump pipe
4. replace o2
5. reverse
I could probably help you out doing it if you want, but not this weekend (too many essays due)...next weekend would be fine.
Ill give my fuel economy report too... still yet to fill her up. I replaced my spark plugs at the same time, the old one were pretty rooted.
4.
Ian
I used a 22mm ring open ender, it was tricky but it worked.
The Gallery works OK, I just went to "My Photos" (it's on the left top) then "Upload Photos" (that's on the right top). "Browse" to where the photos are on your hard drive. Then "Upload/Submit". Pretty simple actually.
:P cheers :)
Edited by Sydneykid
:O cheers  :D
ah, that explains it - I have no "My Photos" option, I'll do a post in the right section to say I have a problem..
Ian
Alex
Slightly OT but what was the part number of the o2 sensor you got from nissan? It looks like it has 2 black wires and 1 white or is that correct or something else? oh one last question, how much?
Sorry for so many questions!
Thanks!
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
