Is anyone else here doing the City-to-Surf in Sydney on the weekend?
A few of the NSW guys are.
Basically - just want to say good luck, and I'll see you at the finish!
I'm in the HSBC start group (blue) and will wear an SAU shirt of some description - so if you see me in among the 75,000 other people - say hi :D
It's on Ch 10 live from 9.00am to 10.30... but that's probably only in Sydney.
https://www.sau.com.au/forums/topic/83839-run-run-as-fast-as-you-can/
Thanks Dark :D
The rest of you can all go to hell!
Am sitting in the gate-lounge waiting for flight now. Went for 5km jog this morning - so feeling good. Once in Sydney - shall do some power-eating (beer has carbs too :angry:) and get ready for the morrow.
Should be fun - will be wearing my SAU Autosalon t-shirt for some represent!
Flight boarding now - see ya!
Hehe - Thanks guys :(
Drove the course yesterday... that hill looks nasty. No wonder its called the heartbreaker. Just loading some beats onto the iShuffle - and will head in.
Fire up!
75mins - very happy with that.
I feel as old as Clarkey and think I need a hip replacement.
Was good though - spectacular day here.
Well done mate. Spectacular isnt a word I would use to describe the weather here :lol:
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
