  • Replies 520
Posted Images
freakin r33 gts-t box still has not arrived. very good chance i shan't be having box in in time for this drag day. if so, it's goodbye to slicks, and hello to numerous pairs of street tyres which I plan to destroy.
doodz. All the relevant info on the Drag Day is in the first post.
But I will help you out here:
Track opens 7:30am
Sign on 8-9:30am
Driver briefing 10am
Racing 10:15 to 1pm
Lunch 1-1:30pm
Racing 1:30-4:15pm
This time there will be 2 crew, 3 spectators and 1 photographer permitted per driver. The photographer is nominated so as to avoid too many people milling around the pit area.
I have just read the words "per driver" in your quote.
Because my car will have two drivers do I double the crew, spectators and photographers ?
I hope so as I am paying nearly double the fee.
Would like this clarified by anyone in a position to do so.
El Bee
Ok the man with the answers is here.
elbee - your second driver actually takes the spot of your first pit crew.
doodz - you can come with me but no friends unless other entrants put them on their lists because I don't know them. In return you can help me with the bbq and drinks stall. We need a couple of other helpers too people.
Parking is no problem.
That sucks. What have I paid all this extra money for ?
There are spectators that I would like to invite, and spectators that my Son (2nd driver) would like to invite.
NXTIMEs quote clearly states "per driver".
El Bee
ps. Didn't pay any extra for 2nd driver last time so understood then. This time is extra $100.
Guest
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
