bwahahaha who's this spy and what with this "I can't show you my engine bay as your a spy for Buster" hahaha has Buster opened his own workshop? mmm nope
guess I'd better get the car finished for this show down, no use in having spy's out there and not racing
  • Replies 520
Posted Images
i heard from busters spy's friend's sister that buster has the hugest turbo ever and a secret inlet manifold and naws. the size of his turbo is dwarfed only by the size of my wang... now that is a serious turbo...
this just in. After reading my post it seems someone has gone on an upgrade mission. i've been sent this pic of spys mate with the T88. seems word has gotten out about busters 'two of the big ones'...
Adam,,,I'm interested but I don't understand a few things, can I run my Sports Sedan and what sort of licence would I need?. If I need to purchase a licence and/or alter the car,,, what sort of money are we talking. I have a budget to run my car and don't want to blow it just to see what it will do in a straight line.
Neil.
They were happy to let UAS John run unregistered last time. Just need an ordinary drivers licence and some ownership documents. Have you got a rough guess of the time it might run?
Adam, as usual count us in mate :D:D:D Will send you a PM about it
I could also have a possible 10 other entries unless they join this forum as well and express their own interest....
Adam, clean out yoru PM's as well mate :):D
My pm space shrank overnight. I'm innocent!!!!
Bring em on. You can deposit the money for them if you want or they can email me at sarpi at punkass dot com. If they are completely removed from us then I would like it if you organised them a bit. Send me an email or pm if you have any more questions about it.
I think this one might be even better than the last one.
John had to get tech inspected first!!!
Call Geoff Crisp @ ANDRA on 0414254135 and organise to have it checked over before the meeting.
Adrian
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
