  • Replies 520
Posted Images
Weellll I hope it doesn't rain. Check this thread before you leave in the morning.
Also entry will be via the spectator gates which are a bit further south around Ferrers road so as to avoid congestion with the A1 Grand Prix.
COMING FROM THE EAST
Those approaching from the east should turn off the M4 Motorway at the Eastern Creek Raceway turn-off at Reservoir Road, turn right at the bottom, proceed north to the Great Western Highway and turn left (west), and proceed 2 km to Jack Brabham Drive, where you turn left. Following Jack Brabham Drive onto Ferrers Road around the northern and western boundaries of Eastern Creek Raceway (ECR). Immediately after passing the south western corner of ECR the drag strip will be visible in front of you. The first entrance is for Competitors. Spectators are to proceed 500 metres further along Ferrers Rd until they come to the Spectator entrance.
Sounds right?
What time is everyone getting there? Links? I think ill get there at 10AM?
Doodz - i'll be looking for a 10am arrival.. depending on traffic for the A1 - could be good/bad..
Which way you gonna be heading out there..
No one wash their car - that way it won't rain..
Edited by Links
OK - now I could be in trouble be ccause i'm posting at 1:52am.. but anyways..
doodz i'll ring you when I get up maybe we can meet up somewhere...
the rest of you - prey it doesn't rain and i'll come say hey.. and take a photo..
damn pubs... they always make you drink... :(
links
:P
Guest
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
