Hey guys,
Well as one of my turbos died last week I've considered an upgrade....
Someone has offered to sell me these turbos:
Group A N1.....the code is something like 14411-06U-00
R34 V Spec II
AR 60-64
5 degree cut rear wheel
360 degree thrust bearing
Steel wheels
Is there some way i can verify that they are of an R34 VSPEC II?
They've done low kms and look to be in great nick.
He's saying he wants $1000 bux.......good price?
Also, how will installing these turbos on my standard R32 GTR improve performance? It has nothing, except for Apexi airfilters and a full exhaust system.
Cheers,
Ali
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/
  IOWNU said:
Hey guys,
Group A N1.....the code is something like 14411-060-00
R34 V Spec II
AR 60-64
Steel wheels
Cheers,
Ali
part# for 34N1`S are 14411-AA403
14411-06U00 are R32 nismo
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1518357
From what i understand the N1 turbo's have a slightley larger turbine blade than stock giveing a small power improvement for the same rough amount of boost. Of course the main bennefit is that the turbo blades are steel, instead of the stock ceramic ones. This means better reliability and the ability to run more boost than the stock turbos.
The N1 turbo's were designed by Nismo for competition use, offering the best trade in their opinion between response and power. Their the best option for the price for track GTR's, road/race GTR's and fast street GTR's. The spool up time is almost identical to stock, but you can also run boost levels up to 1.3-1.5 bar without fear, unlike the stock ceramic ones.
With the appropriate other mods, Exhaust/IC/Fuel System/ECU and 1.4Bar ive seen a few GTR's make anything between 260KW-330KW at the wheels, depending on tune and dyno.
For $1000 id say they were a good buy.
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1518568
  IOWNU said:
Hey guys,
R34 V Spec II
AR 60-64
Steel wheels
Cheers,
Ali
i wont waste your time on this turbos personally
the turbos you want BRAND NEW are the garret replacements 707160-5
racepec are selling them for around $2400 new
the reason i say dont waste your time are the r34 vspec turbos are still ceramic turbine wheels and still fail and if they fail under the wrong conditions will take the motor with them (like the last r34 i built) and the group "a" are laggy but strong
the gt2560r 707160-5 i use in a light modify combo ,generate well over 500rwhp with basically no lag what so ever (have done a number of these combos now)
so for a little more money now you will never regret it later.
pete
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1518601
OK bit of confusion, the code hes given matches R32 nismo code, but he reckons that the paperwork is in fact of an R34? Anyways....
Thanks for the feedback guys!
Hopefully i get the turbos sometime today....will take pics when i get them!
Cheers
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1519659
pete
He was asking about R34 N1 turbos, but I agree with your comment on the Vspec turbos. Did a conversion on the RB25DET with a pair and the front turbine let go at 5psi. Damned ceramic crap.
The R34N1's use inconel instead of steel on the turbine wheel.
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1519704
Still seems a good price for N1 turbos. The advantage of the R34 N1 is the roller bearing and the inconel turbine.
Just for interest, my turbos are steel wheeled stockies on the GTR, and they produce 260rwkw at 1bar with the stock computer so the N1 should do a bit better. While it's apart why not get some decent dumps and a set of UAS extrude honed manifolds? Of course it's more cash but the time is right.
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1520129
  MIU said:
this turbo 100% not R34 N1 turbo,couse R34 N1 turbo got separate wagste at back of turbo and R34 V-spec2 use same turbo as R34GTR,no any different.hope it wil help.
the one you got more than likely are R32 N1.not Nismo turbo.
couse Nismo turbo's code are RR580 or RR581.
just to ad to the confusion
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1520144
How much extra dosh are we talking, for the dumpa dn UAS extrude honed manifolds? How will they improve performance? Sorry for the basic quiestions, but although i've owned a whole stack of imports, i really haven't gone all gunz blazing in modifying them......
LoL....that pic with the code saying its nismo has confused me now......so are they normal n1 or nismo n1.....or what not.....:S
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1520151
  GTRgeoff said:
I thiink they were called Nismo on the R32.
Take a look at www.nismo.com.au for the UAS stuff. JP is on the forum here as boosted zed and has done some posts on the extrude honed manifolds.
Thanks for the help mate,
appreciate it.
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1520181
  IOWNU said:
Alright cool....
still no word on improvement on performance?
Please search mate.
The topic of GTR N1 turbo's comes up all the time.
and the usual response is they arent as good as a set of HKS 2530's which are better in every area.
The N1's arent the best turbo. 32 N1's (as it seems these are) are a cheap upgrade, and will get you more power.
But get into a car with a decent set of turbos and you'll cry everytime you drive yours for overlooking it
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1520261
I tried searching.
The search engine kept telling me something along the lines of "less than four characters" so i can search......that ruled out N1 and GTR. Leaving...turbos. LoL
yeah agree that the HKS turbos are better, but I'm just chucking these on as the budget option, until Jan, when I will sell the car.
https://www.sau.com.au/forums/topic/83853-r34-n1-turbos/#findComment-1520399
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
