I thought I would share my experiences modifying an Auto R33 GTS-25t since Im nearing the end of my modifying experience.
Bought the car totally stock down to its rims and 205 tyres
1996 R33 GTS-25t Skyline Series II
with 69.000 Km on the odometer mid 2002
Took it down the 1/4 mile best I could get was 15 Flat
STEP 1
Apexi Air Filter
TRUST V-SPL Intercooler Kit
3" Front Pipe
High Flow Cat
Trust MX Cat-back
Profec B Spec I EBC
With stock ECU it would hit fuel cut with any increase in boost
then again, I had no idea what boost it was set at because I was still using the boost gauge in the stock instrument cluster
Never went to 1/4 mile or Dyno but I can tell the most difference came from the FMIC followed by the EBC followed by Exhaust
STEP 2
Fed up with fuel cuts I got myself a SAFCII
along with
Bosch 910 Fuel Pump mounted externally
Malpassi 2:1 Fuel Pressure Regulator
HKS256 Exhaust Camshaft + Cam gear
Apexi Boost Gauge
King Springs (The damn thing looked like a 4WD, needed some lowering)
Replace Timing Belt
Result 273Hp@11Psi
At this stage I should have been satisfied with what Ive got but No I got used to it and wanted even more, it sorta got out of hand after this
STEP 3
Wolf3D Programmable ECU
HKS 2535-56T
3"Dump Pipe
Nismo FPR
Greddy Oil Catch Can
MV Automatics Shift Kit (Valvebody upgrade)
Auto tranmission cooler
Stainless Inlet Piping
Result 300Hp@14Psi
Running a very conservative tune due to stock injectors kept ignition timing on the mild side. The shift kit + wolf made driving just that little bit less comfortable but on Snow mode and a little less gas it wasnt that different to stock
Any more power pass this point is going to be a concern to the gearbox so I thought a transcooler would be a worthwhile investment
13.034 @ 109.89Mph
So close yet so far to 12s ehhe
Damn these 205 tyres!
still manages a top mph of 113
STEP 4
450cc High Flow injectors from http://www.deatschwerks.com/products.html
HKS 256/264 Camshaft
GAB adjustable damping shocks + RSR springs
Blitz Sonic Filter Copy (With heatshield)
Result 328@12PSI
Well the cams definitely makes some difference, More power for less boost. Thats always good.
The auto gearbox seems to be holding up well so far, who knows how long it'll last even with the modifications
It just never ends! this time the coil packs arent giving me enough spark
DAMN THESE SERIES II COILS! Not sure how much boost I should be running with stock internals, or how much the turbo can supply before running out of efficiency.
Guess final step would be
Splitfire Coils
Rims+Tyres
STEP 5
Maybe I shouldnt have said final step cause somehow one thing led to another and due to busted piston rings the following things are now in the car
RB30 Block, crank, rods
ARP Rod Bolts
CP Pistons
Head serviced and polished
Splitfire Coils
Nismo Fuel Pump
SS Exhaust manifold
Autometer oil temp, water temp, oil pressure gauge, Gearbox temp gauge, Volt gauge
Endless SSS brake pads
HKS SSQV BOV
255/50/16 Mickey Thompson Street ET Drag Radials on 300ZX Rims
Still running in the engine at this point but the torque is awesome, I drive arround in SNOW mode which is practically 2nd gear and it feels like Im on 1st gear in the old RB25. Who knows what will happen to the auto gearbox haha
Result 332.6 rwHp thanks to Steve and Steve and John, from Top Racing
The turbo is too small, restricting exhaust gas flow, making the stainless manifold glow red hot with superheated air, looking for something slightly bigger in the future, but even with this much power, traction is an issue not sure what can be done. Cant wait to hit the 1/4 mile with the mickey thompson.
Tried it once and I blew my hose clamp ahhaha hoping for more luck next time
They dyno comparison shows the increase in mid range going that extra 500cc
Finally got arround to getting proper times at the drag strip
Best ET so far of 12.5@114Mph
60' of 2.089
The Torque Converter is really limitting the launch capabilities of the car considering the tyres I have on them. Only able to launch at arround 2750RPM at best (and thats with car inching forward before the green light) And my rear shocks have just shat itself (I'm pretty sure there is no oil left in them ahhah)
Next time hope to be able to get a sub 2-sec 60 footer. Would be better with a higher stall but at its current state, should still be able to get further into the 12s
STEP 6
After a trip to 2007 Tokyo Autosalon, couldn't help myself splurging a little
HKS 3037 Pro S 56T
Top Fuel Power Neo
Apexi Grounding Kit
Engine Damper Kit
HKS Hi-Power 409 3.5" Mild Steel Exhaust
Result 435rwHp@21Psi
Went back to stock exhaust manifold, those low mount stainless manifold are crap and crack easily
Much better Power delivery now, more linear, more controllable
First gear is actually usefull again!
1/4 Mile time
[email protected]
With overdrive OFF, it was hitting the rev limitter at top of 3rd Gear
with overdrive ON reached 121.45Mph
Suspension Mods:
Whiteline Swaybars Front & Rear
JJR Castor Rods
Rear Camber Bushes
Greddy Type S Coilovers
GTR Rear Strut Brace
Nismo Rear Strut Brace
Do-Luck Chasis Brace
HICAS Lock Bar
Suspension Pineapples
Edited by lukits01
Nice!
I also plan to do my Auto S2 R33 up abit (180-200rwkw goal) and your post has been informative in telling me what I need to modify to get it.
What do you think you would've got on the dyno after step 1?
Thanks.
Nice!
Thanks.
I dunno, probably around 170ish rwKw with a very shitty power curve
I heard Series II ECUs can handle more boost before hitting the fuel cut but it didnt seem that way from my point of view
  • 10 months later...
Interesting result, still appears to hold power well to redline.
Does it feel as if it wants to rev to 6.5k still?
Next time your down at your new tuner have him give it a quick power run in SHOOT6 or SHOOT6F mode. Most likely you will see a small increase in power. It will then be comparable to the last one done on SST's. :)
Interesting about the HKS2535 turbo , they're supposed to use a compressor in between the 2530 (60mm) and 2871/GT-RS (71mm) . I think HKS blurb quotes 69mm 84T so probably the closest available compressor for the high performance GT28 turbine .
If you can read the turbos ID tag may I have its numbers please . Also if you remove it some pics would be handy .
Cheers A .
Do me a favour and delete all references to boost cut, there is no such thing, The standard R33GTST ECU doesn’t even know what the boost is. It is excessive airflow as noted by the AFM which sends the ECU in to rich and retard mapping. Call it "R&R Mapping" for short.
I love the way the turbo runs out of airflow and can’t hold the set boost level.
I noticed that you have used the standard RB30 conrods (did you also use the standard RB30 rod bolts?). If so, I wouldn’t be going much over 300 rwkw (400 rwhp).
:P cheers :D
Edited by Sydneykid
Nice to see the auto getting some more airtime
I have been modding my auto R32... nowhere ner as much as you though. I took it from less than 100rwkw in stock form to 155rwkw in its present state with more-or-less the stock ECU :P
Love the way it drives...
best of luck with the rest of the upgrades!
Warren
Point taken hehe and editted
Using ARP Rod Bolts, Was aiming for 300rwKw but considering my right foot is still not up to the task of handling 250rwKw I'll hold on the turbo upgrade
I havent redlined it that much, again was more concerned with the first few thousand RPM. Gay thing about the Auto is it can randomly and unexpectedly kick down on you, and with this much torque... its scary
The turbo if I remember correctly say 2535-56T there are some other numbers on the tag but I dont remember what it said
The Dyno I believe is the same for most of my graphs except that time I went to hyperdrive
I noticed in your last step you went to a different exhaust manifold.
Is it a high mount or low mount and does it have the same type of heat sheilding as the factory item?
I ask as the last dyno chart posted has an inlet temp of 55degrees, nearly 30 over ambient where it doesnt happen that far previously.
Yea noticed that too, the stainless manifold is a low mount manifold
One of those internal gate manifolds that place the turbo in the stock location
Its only slightly better than stock, and Im starting to wonder if its worth the effort
Theres no heatshield on it so was thinking of doing 2 things:
1. Fabricate a heatshield for it
2. Move the air filter into the front bumper in front of the wheel arch where the stock intercooler used to be. Since its a Blitz style air filter, it has the shield which stops water from the wheels from spraying all over the element
Ive allready raised the bonnet with washer in an attempt to get the heat out of the engine bay as well as to get more clearance on the intake manifold
IT of 55 just means the sensor is where Dyno Dynamics suggest it to be.
For a Turbocharged car however, its essentially useless.
Just have the sensor in the ambient temp somewhere not near the engine bay
Steve told me about your car lukits01 as im thinking of going the HKS GT2535 turbs on a rb30det aswell (have it on the 20det). Whats it like to drive? boost come on like a jet?
I hope Lukits01 doesnt mind, but i though i'd add my mods and progress to his thread to keep it all in one spot... just let me know if you want me to start a new one mate.
My car is a SI R33 4 door Auto. 128,000 kms M-spec
I've attached a graph of combined dyno runs i've done as i changed things, all on same dyno, all tuned by me.
The BLACK line is as i recieved it ... (on this dyno std r33 autos are about 115 rwkw) , this had a Fujitsuboto "jasma" spec cat back and a 3" full dump fitted and a pod filter. So it had abit more that a stocker.
The GREEN line is LINK plug in computer, converted to MAP sensor, Splitfire coils. Boost was 11psi rolling back to 9 psi from midrange onwards ( Using the links boost controller to roll it off, as trying to maintain 11 psi actually closed the wastegate sooner and power dropped off... by asking it to do lower boost the gate stays open and power stay higher for longer) , R34 GTT SMIC upgrade. ran a 14.3 @ 98MPH 2.95 60' !
The PINK line is Hiflow turbo (VG30 rear housing, new turbonetics center, Garrett Stage 3 To3 Turbine wheel, Rx-7 front cover with a V-trim hiflow wheel (6 blades not 8 like the V1/V2 has) , 550cc Nismo injectors, MV Automatics Shift kit, FACTORY Airbox fitted, with Apexi filter. Bosch 040 intank fitted.
Power was abit lower than i expected, even limited by the cooler size, so i checked the exhaust back pressure, and to my horror saw 11 psi BP on 12 psi boost. !!
Ran a 14.5 @ 102.7mph 2.5 60' (with MT ET Street tyres, but note it was raining .... they had 20 cars running over track to dry it out abit !!!! )
The RED , YELLOW & BLUE lines. Just removed rear muffler, and welded on a temp cannon cheapie (2 new SMB's on the way soon) .. Got to 207 rwkw doing constant ramp runs with changes etc .... , then let it cool and did the final run in BLUE.... So fair indication a front mount cooler would help lots to keep the power constantly around the blue range, would dare say it would be back the the red area 1/2 way into a drag run.
With heat soak. Just ran tonight , finally got a 13. Ran 13.831 @ 109.75 MPH 2.59 60'
I just cant get it off the line.... tried all different styles 60' was very consistent between 2.59 to 2.68.
I guess the cooler and cams help yours out alot Lukits ? (edit, got a genuine hybrid)
Also called Mike at MV Autos to look into a 2800-3000 rpm Street stall converter (retains lockup too!) .. that will help immensely i would imagine ! Still the good thing about it is you lift the bonnet, and it looks totally stock... full heatshields etc :thanks:
Gary
Edited by Fastrotor
Boost pretty much always there as you can see from the dyno's absolutely no/little lag. doesnt really come on like a switch, very linear. Great to drive arround with, control the ammount of boost with the throttle, and the torque makes overtaking easy hehe
I guess the cooler and cams help yours out alot Lukits ? ARC cooler is being procured soon from Japan...
I dont mind, quite the opposite actually. Nice results very similar to mine. Is that torque units suppose to be Nm? or LB/ft or KG/m? cause you have more torque than a Mercedez Benz 6.2L V12 Twin Turbo
Cooler will definitely give you a big gain and more consistent power runs and ARC coolers are suppose to be one of the best, wish that was available when I was looking arround for coolers. Cams really only needed when you change turbo or if you want that little bit more midrange. I just happen to come accross my set 2nd hand relatively cheap so I went for it.
and as for getting of the line, I fine stalling it up with left foot braking and e-brake then letting go at the last yellow lights to be the best. after that its just throttle control. Tyres offcourse play huge role in 60' time. Then again what would I know, I managed to spin on the drag strip once ahahhaha narrowly missing the wall
Is that torque units suppose to be m? or LB/ft or KG/m? cause you have more torque than a Mercedez Benz 6.2L V12 Twin Turbo
Torque is multiplied though the gearbox ratios and the diff ratios when running on a dyno. Hence not comparable to engine torque quoted by manufacturers.
:D cheers :wub:
Yeah its in Newton Meters, and as Gary has pointed out , its rear wheel torque, not motor torque.
Yes i think the cooler will help immensly.... Does anyone reading this know if the ARC coolers are able to fit without cutting the reinforcement bar whatsoever ..?? I just like my insurance thats all.
Gary
I ended up getting a genuine Hybrid GT cooler (after much searching for a genuine distributor, wayyy to many fakes around!) Decided i didn't want to spend over twice as much for the arc, plus the ensuing wait from Japan.
Didn't buy the piping kit as i detest the over the radiator method, and also cutting holes in my car ! Will plumb it up myself. (yet to see the nightmare i could have let myself in for)
Also just spoke to Mike at MV few minutes ago and he's finally got a spare converter out of a R31 he can mod and send up for me to swap over, as i didnt want to pull mine out and then wait to refit.
Exciting ! I'll try to have it all in by the end of month, before next circuit sprints.
Gary
