she  reckons they did it on a air strip so room wasnt an issue, i just wouldnt beleive that the auto trans and let alone a 1600 would be able to push the car that farr, top gear in an auto would be redlining before it got up to 230 even wouldnt it? and it looked like a stock car pretty much...
They got a tow from a plane taking off. :lol:
Lets kill this one off right now, I don't have my Honda gear ratio chart with me, but from memory the manual B16A does 27 kph per 1,000 rpm. So 280 kph would be 10,370 rpm. So it's IMPOSSIBLE :)
But wait there is more ;)
If I remember rightly the auto is 8% shorter geared, so that would mean 11,200 rpm at 280 kph :lol:
:) cheers ;)
Edited by Sydneykid
whats a r32 gtrs stop speed btw?
I don't have my gear charts for Skylines with me either, again from memory 275kph = ~8,500 rpm. If it has enough power to push it there of course. At Philip Island we get to around 265 kph on the main straight which is somewhat downhill, and that's with 380 4wkw
:) cheers :)
hey. Its 12.20am and just got back from a burn in my mates s2k. THAT can definately do 280.... We onli took it up too 250 before i asked him to back it off. Thats a h22 in there but...
We took his type r integra up too 240 as well without too much of a sweat so i rekon it could do 280 without too much hassle. BUT i believe thats a b18 or sumthing in there.
That being said, it would barely be able to do 280 without some mods so i definatley dont think that a b16 could come close.
***all done on a legitimate track**** none of that open road shit.....
Interesting, the F20 turns clockwise and the H22 turns anti clockwise, so that 250kph was in reverse, right? ;)
:) cheers :D
Theoretical top speed for a R32 GTR is about 250km/h. Don't need a rocket scientist to figure out that a RB26DETT has more torque than a B16A engine. I don't care what aerodynamic coefficent a Intergra is it'll never reach 250km/h (unless a tornado is blowing wind in the right direction and plumetting down to earth from orbit, YES, it may reach 280km/h).
Just cause the speedo says, doesn't mean it can do!
true but a type r teg is not far off. i was in my mates and we got it to 240km/h which i call close and damn good for a 1.8.
and yes i no at speeds like that that the speedo is not quite accurate but i am just saying what i have experianced. :P and civics have B16A integra B18C.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
