Hey all excuse the newbie question. Im in the market to buy an exhaust for my R33 series II and Ive come accross two types Cat back and Turbo back exhaust whats the difference price,noise etc?? Also ive seen cars with exhausts and if you look inside the cannon they have these ugly restrictor looking things which I dont want whats with these things? I just want a cannon that is a proper cannon muffler not restricting the exhaust gasses. Any input would be highly appreciated.
https://www.sau.com.au/forums/topic/83905-real-quick-and-easy-exhaust-question/
cat back is from the cat (catalytic converter about half way up the car) to the rear of the car
turbo back is from the turbo all the way to the back of the car
it includes the dump and front pipe which is the section between the tubo and the cat a high flow cat and then the cat back system.
the rectictor thing ur talking about im guessing is a removable silencer thses and just bolted in and can be easily removed
get a 3" cat back fitted/supplier at your exhaust shop and get a 3" split dump from batmbl and you get best of both worlds. give the split dump to your exhaust place and get them to fit at the same time.
the split dump will remove turbulance off the exhaust housing and allow it to flow more as its not being forced down out a 2" exit (i think the stock is 2.25" actually). it will flow more it top end as it wont choke and the car feels fantastic after this is done. also the turbo spool up noise is a little bit more auidable with a larger dump and front pipe combo
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
