Ok, did a search and couldnt find info from anyone whose done it...so ill ask the q's ive got here....
I need new rotors and new pads for the r32 gtst. I understand r33 rotors are larger, and that the r32 calipers are up to the task...
So i want to fit r33 rotors (or the largest i can fit :D ) with some freshly rebuilt r32 calipers, using new pads...heres the q's :angry: :
1. Looking at the www.dba.com.au website, can anyone tell me whats the part number of some r33 rotors (DBA4000 series, wiper slotted surface, with kangaroo paw inner)? Or can i go larger in size? (currently have 16" rims)
2. Where can i get the new caliper mount to offset the larger rotor, and do i need one?...also how much should it cost? :angry:
3. Anybody got the workshop diagrams for the r32 calipers, so i can rebuild them? Is it hard to do yourself, or best left to a workshop?
4. How hard is it to swap the rotors etc, yourself?...
:lol: cheers
https://www.sau.com.au/forums/topic/83910-r32-gtst-new-rotors-and-pads/
Your GTST will have 280mm rotors, the R33 uses 296mm and R34 310mm. You can run the 296mm rotor, but you will need to use the R33 caliper, did the 310mm ; you will need the R34 caliper.
Problem with trying to use a bracket to offset the rotor that is only 16mm bigger, is well condider the bolt holes are somthign like 12mm, so by the time you drill the two holes next together, there isnt goign to be much meat in the bracket between the hole centres :angry:
So the best bet is sell the R32 caliper and rotor to an S13 owner, and put that money towards soem R34 GTT calipers, then run something like the DBA4000 rotor. (or std rotor if its till in good condition)
Next best bet is grab R33 or R32GTR calipers, check the condition of the seals and pistons etc. And throw on the DBA4000 296mm rotor.
I think the 310mm may need 17" wheels, never really checked though. But if you want to use the R32 caliper you currently have, then let me know what budget you have as i may be able to sort a nice curved vane 324 x 30mm rotor with adaptor to offset your caliper for reasonable price. Are you after slotted, slotted/cross drilled????
See above
Take the caliper off, and give them a clean..all will be revealed. its not difficult to re-co them and inspect them yourself. Th eonly tricky thing is the grease you use for re-assembly
Piss easy, two bolts holf the caliper on, remove brake line if your goign to service the caliper and the rotor should fall off. If it doesnt the rotor has a tapped hole that you cen screw a bolt into to help pry off the rotor if they are rusted on. Just check everything is tight when all goign back together :angry:
Oh...and remove the dust shield while you are there...cut cut cut :D
r32 gtr would be an easy upgrade, straight bolt off, bolt on. all you need is the discs and calipers. I've got some in my shed you can have a look at, quite a bit chunkier than the ones you've got now. I dont want to sell mine, but you can have a look to get an idea how they differ.
Oh, and to make the job all that cheaper, I have a mate that would be interested in your current set up.
Cheers Troy, was hoping you'd see my thread :P
Im interested in the 324 x 30mm rotor with caliper offset mount...but would it need 17" rims to fit as well Troy? I really dont have the cash to upgrade rims atm, but 17" are on the list...or better 16" rims (still undecided on that path). If the will fit the 16" rims, tell me more :D
Im after slotted rotors only...
So as long as i use the caliper that is normally used with the rotor, you just bolt them up? The caliper mount stays the same?
Will let you know mate, depending on what Troy can do for me.... :D
im using 32 gtr calipers as new 4000 dba discs will be very similar costs for all three options and pads are the same so have a look around for some cheap calipers for sale, it will be cheaper i think to buy some gtr 32 calipers and sell yours then you can use off the shelf rotors with no adapters needed, add some braided lines and good pads and your set. I dont think there is any need for anything larger in a 32 unless you do serious track work
I have noticed with the bigger motor i need to pull it up a tad harder these days :P Pads dont last as long either....
I guess id like an easy upgrade, and the way others have said to sell my gear, then go larger calipers and off the shelf rotors seems nice and easy....
Take the caliper off, and give them a clean..all will be revealed. its not difficult to re-co them and inspect them yourself. Th eonly tricky thing is the grease you use for re-assembly.Oh...and remove the dust shield while you are there...cut cut cut :P
What kind of grease is needed? I think ive got a fresh jar of high temp. grease...HTB? is the one i got...its grey in colour. Will look later to find out.
Why do i want to remove the dust shield?
Dust shield generally means higher brake temps...not a bad thing on the street where you want your brakes to come up to temp quickly and be ready for that one big stop when required. But in spirited driving they get too hot all by themselves so every bit of free cooling is good.
As for the 324mm they do need 17' wheels. Its up to you what you want to do, the 296mm would still be a good upgrade....and i think the bigger rotor gives a nicer feel under brakes...others that have driven the car seem to say that it stops nicely..actually you have driven the old girl, though i cant remember what pads i had in ti back then, i think they were jusr RB74s.
Ill do some numbers and shoot off an email reagrding some options other then the DBA route...
As for the grease...i got no idea, all i know is that it not the sort i put in my hair...
Perhaps ring the local brake joibt and just make out liek you know the stuff; yeh, yeh, just some of the grease for the caliper pistons thanks, yeh you know the one" :P
Actually did a search, and its not exactly the same for the Nissan caliper but its close enough to get you goign, and with the caliper in front of you, well you can easily suss out the rest
http://www.bmw-m.net/TechProc/caliper.htm
http://www.performanceproducts.com/Product...+Grease&type=10
http://www.racerpartswholesale.com/crccaliper.htm
Cheers Troy :P
Looks like i need to use some Castrol GRRB grease... :Castrol GRRB
A rubber compatible castor oil-bentone based grease ideal for packing rubber dust covers of hydraulic and mechanical brakes. Also ideal for use on rubber seals during brake assembly.
http://www.castrol.com/castrol/multiplepro...ntentId=7000402
Sounds the one, years ago when a friend adn i were doing a 200SX i think we used PBR...but sounds like the same thing. Interesting to read that BMW How to suggests just to use brake fluid, makes sense i suppose...i popped a pston out the other week when i was tryign to rush a fluid and pad change, only i forgot to put the pads in, and upon haivn to put th eiston and sealetc ack in, it appeared that Race Brakes had used grease after i had my calipers HPC coated
But what happens when water gets inside your calipers? Brake fluids hygroscopic(?), & your pistons wouldnt be as "lubed up" after a period of time, then would sieze if not serviced regularly...
Ill stick with the grease still :P
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
