hi guys,
I am really interested to buy a GTR32, but all of us know it is a car over 10years old already, so it is pretty hard to get a good one.
Before I go for inspection, can you guys tell me what sort of things do I need to look for?
And I will take the car to the workshop too, but what kind of testing do I need to do? Especially about the engine........
I live in Melbourne, can you guys recommend any work shop can do good testing and how much will it cost?
Any information will be helpful
:P
https://www.sau.com.au/forums/topic/83960-buying-a-gtr32/
