  • Replies 50
can you get the type B core? whats the difference? ARC do list a 100mm thick cooler.(M103, M109)
Does the M073 come with piping? and have a size of 450x700x70? If so you may have a deal.
Can u also get alloy radiators?
Edited by BOOSTD
lol.
sorry the avatar has nothing to do with what engine he actually has its regarding post count.
very nice cooler though wish i'd held off and bought an arc 1
Yes M073 kits comes with piping
M103 for BNR33 - $1,899.00 (100mm thick)
We have to check on the specification
Radiator> we can get ARC, Trust, HKS, Apexi, etc
BT - are you sure the ARC GTR kits come with piping? I thought the GTR kits were core only (as they just use stock piping). ARC coolers really are so nice. I have the latest ARC goods master at home as i got it from their stand at TAS. I'll have to have a look at it as i may need a cooler for the new car and you seem to have very good prices.
Beer Baron - we are double check now
n15m0 - ER34 ARC side mount actually cost more than Front mount
because the thickness is 100mm.
Price: $1,969.00 landed
Front mount starts with 70mm thickness
GoldZilla - What engine does it have?
It has an RB25DET, but I would prefer an intercooler where the return pipes go either behind or under the core so I can utilise the standard holes under the airbox. I would rather not have to cut holes or have the return pipe go up and over the fan...
Thanks in advance,
Nick
Holy crap!! thanks but no thanks..will try my luck sourcing a 2nd hand one...
hey can i get a price on an ARC intercooler for an R32 RB20DET motor, also does the ARC use the stock piping route if you know what i mean. ps i'm in sydney so also how much to here. thankyou
It is called Cross Flow Kits - price is the same $1,399.00
However, Cross flow kits will have a smaller core dimension.
Cross Flow
HCR32, ERC33 - 260x470x70mm
ER34 - 260x600x70mm
Edited by BT-Revolution
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
