SLY33 Posted August 18, 2005 Share Posted August 18, 2005 anyone? Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/ Share on other sites More sharing options...
MANWHOR3 Posted August 18, 2005 Share Posted August 18, 2005 anyone? <{POST_SNAPBACK}> Degree of difficulty is high. not worth the trouble. just sell and buy one with abs. Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1529766 Share on other sites More sharing options...
SLY33 Posted August 21, 2005 Author Share Posted August 21, 2005 Degree of difficulty is high. not worth the trouble. just sell and buy one with abs. <{POST_SNAPBACK}> that would be easy if i hadnt spent so much on my car! selling to buy one with abs is not an option! Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1535307 Share on other sites More sharing options...
dangerous_daveo Posted August 21, 2005 Share Posted August 21, 2005 I dont mean to sound rude, but just learn to brake without abs. Technically you should be able to stop faster, if your good it wont unsettle the car as much blah blah blah. You might get the odd lock up here and there, but hey, you get that. Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1535398 Share on other sites More sharing options...
Baz Posted August 21, 2005 Share Posted August 21, 2005 I agree with daveo Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1535589 Share on other sites More sharing options...
Haysey Posted August 21, 2005 Share Posted August 21, 2005 it would be handy and might make a prang less expensive then without abs.... but otherwise do a luffy course or something where they teach u.. its good! Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1535771 Share on other sites More sharing options...
dangerous_daveo Posted August 21, 2005 Share Posted August 21, 2005 Oh yeah, and just leave REALLY big gaps in the wet Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1535813 Share on other sites More sharing options...
KamikazeR33 Posted August 21, 2005 Share Posted August 21, 2005 abs does help if ur on the track using slicks.... thats bout the only advantage really Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1536056 Share on other sites More sharing options...
Drifterdan Posted August 22, 2005 Share Posted August 22, 2005 Good idea, but its a pain in the arse. I'm trying to get rid of the abs in my r32 (the abs unit is shagged) and even that will be a pain.. The master cylinder needs too be changed along with all steel sections of brake line and then in your case the abs computer and sensors would all need to be installed... So basiclly, unless you have a written off r33 with abs fitted then it really is too hard. Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1537182 Share on other sites More sharing options...
_IrIsH_ Posted August 22, 2005 Share Posted August 22, 2005 save the weight Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1537777 Share on other sites More sharing options...
blind_elk Posted August 23, 2005 Share Posted August 23, 2005 ABS is not just the unit sitting in the engine bay. It is a full-blown electronic sensing system. It relies on sensors in the front and rear wheels to inform a computer what is going on, and that computer then makes a decision as to whether or not it needs to tell the ABS unit to bleed off some pressure, and which wheel(s) need it bled. ABS was designed for Joe Average Useless Driver, who has no idea about braking in emergencies, other than to jam his foot on the brake pedal as hard as possible. No finesse at all about that. I learned threshhold braking and I am always watching ahead for possible "situations". As a result, I have a very difficult time getting my ABS to activate - I simply don't get into situations where I need it. So go and spend a lot less than the cost of converting to ABS on an advanced driver training course and learn to threshhold brake (amongst other valuable skills) - the world will be a merrier place. Link to comment https://www.sau.com.au/forums/topic/84022-abs-conversion-on-non-abs-gts-t/#findComment-1540367 Share on other sites More sharing options...
