MY car in from Japan with so much crap on the paintwork - I've washed it, tried cut and polish, turps, diluted washing powder - and it aint coming off easily.
Same crap on my windscreen, had to use a razor blade to get if off - Obvioulsy can't use a blade on the duco.
It's like caked/set muddy dust. I'm guessing it is from being out in the weather heaps whist in Japan.
How the hell do I get it off ? Is there some sort of industrial stregth stuff I can use that won't harm the paint ? Even the red kitten cut and polish won't get it off.
I don't particularly want to spend big dollars on a detailer or panel beater to buff it out.
Any help would be appreciated.
CHeers,
https://www.sau.com.au/forums/topic/84028-how-to-get-crap-of-my-duco/
'Mothers Clay bar'! Cant go past it for what you need. Its about $50 from autobarn. Trust me on this it makes your paint smooth as silk and doesnt remove any actual clear coat. Even comes with a polish too. Just grab it and read the instructions on the pack. You can re-use it plenty of times too.
Cheers
id always use a clay bar before gong to cut and polish because a clay bar is a much safer way to remove the build up of unwanted crap on the clear coat, whereas a cut and polish does just that-cuts the top coat very slightly and then polishes it up. Its good but i'd only use it to touch up anything the clay bar didnt get rid of ie: scratches etc
Also sopunds crazy but use a fine steel wool pad to remove crap off the glass. It doesnt damage the glass. If you want try it on a tiny small concealed area first. Make sure you use sum glass cleaner with it though..
Edited by Godzilla32
Clay bar worked a little bit better than cut and polish but still didn't remove all the crap. It's really baked on crap. Wondering what to do next......
I got a McGuiars clay bar - Is the Mother's one better or are they all pretty much the same ?
What about autoglym ???
This is an industrial stregth problem ...... Ahhhh
My painwork will look sooooo good when I remove all the crap
Help ! ! !
Maybe its just my experience with a clay bar, i never found it did much for my paint.
Instead of going for the Kitten red cut and polish, go for the Kitten Black cutting compound, and then use green kitten polish, n then a good wax.
You will be there for a while, it *should* work, did for me. I had heavily oxidised paint and now its pretty sweet in most areas where i didn't go half-arsed.
Mate if this doesnt work ill drive to where you live and clean it myself.....(not really but you get the point)
DRI-WASH !!!!!!
i swear by this stuff.....with my life
cant say much more so...
http://driwash.com.au/index.html
(but prices seem higher than im paying)
anyway best of luck tell me how you go
any inquires PM me
Ciao
RellikZephyr
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
