Has anyone ever experienced engine oil in the cooling system? before you say the head gasket i have no watter in the engine oil, it is still clean and engine is running well
I was thinking that it could have somthing to do with the Oil cooler as it is water cooled? If any one else with a 32 GTR has had a similar problem let me know what it was?
https://www.sau.com.au/forums/topic/84031-32gtr-oil-in-coolent/
Could it possibly be the heat exchanger?
I had a similar problem in a commodore a few years back. The head was corroded between a water gallery and oil gallery.
Since the cooling system runs at 13psi max, and oil pressure is more like 40 psi, the radiator fills with oil, but the engine still runs good with no water in the oil.
So I'm saying head problem...
You have a water cooled oil cooler? is that an Aus delivered GTR thing? if not what brand does it?
i'm pulling off the oil cooler next week and i'm going to have it pressure tested if it comes back good i'll pull the head off. i was told that it is easier to pull the motor then just the head has anyone had experience with removing the head inside the engine bay?
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
