Item: 1993 R33 GTS-t V SPEC (with ALSD)
Location: Southside Brisbane (willing to sell interstate)
Item Condition: Mechanically A1 serviced EVERY 5000k's at Gavin Wood - Autotech. Female owner.
Reason for Selling: Buying a house
Price and Payment Conditions: $22,500 or reasonable offer
Extra Info:
Model: 1993 R33 GTS-t (V-Spec with ALSD and ABS)... If you have to ask why it's a V-spec because of the ALSD, please search the forums. I'm sick of answering the questions.
Exterior:
  • Recently resprayed white with violet ice pearl
  • Blitz mag wheels 17x9 front and 17x10 rears currently with Nexen 235/40/17’s and Federal 255/40/17’s
  • Tinted windows
Transmission:
  • 5 Speed manual
  • Short shift
  • Organic clutch and pressure plate with R32 GTR Nismo spring. Only just installed on 05/08/05.
Engine:
  • Apexi PowerFC
  • Apexi AVCR
  • Apexi GT FMIC
  • K&N pod filter
  • Tomei exhaust cam gear
  • Splitfire coil packs
  • HKS Superdragger exhaust
  • Nismo dump pipe
  • 3” turbo back exhaust
  • 100,000k service done at 83xxx with genuine nissan parts
  • Currently with 130xxx k’s on the clock. Most k’s have been done during freeway driving.
Interior:
  • Two recaro reclinable racing seats
  • AVCR with two settings 0.7bar and 1bar.
  • Autometer boost gauge
  • Autometer air/fuel ratio gauge
  • A pillar 2 gauge holder
  • JVC MP3 head unit
  • Nismo black gear knob
  • New leather gear and handbrake boots
  • Momo steering wheel
  • Metal racing pedals
  • Fitted with a top of the line Mongoose alarm, immobiliser and central locking.
  • In car GME Electrophone 60 channel (40UHF 20 programmable) UHF radio.
Trying to save money for a house, and we don’t really cruise anymore. We have owned the car since it was imported into Australia in March 2002. Car was last dynoed with ~200rwkw. Best time of a 13.5 @ 103mph.
Contact Details: SAu PrivMsg, or erinatsauqld.com... Happy to give my mobile to interested parties, but I dont want every tyre kicker and joy rider ringing on my mobile. Not interested in a quick sale, so if your offer is ridiculous, please don't even bother wasting my time.
https://www.sau.com.au/forums/topic/84052-r33-gtst-v-spec-with-alsd/
  • 1 month later...
  • 2 months later...
  • 4 months later...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
