Ok Guys I am having a problem with removing the M spec front bar from my S1 r33gtst. I have removed the bolts attaching the bar to the side skirts I have removed the 3 screws under the grill and I have unattached the bar from the lining inside the guards. And unplugged the indicators. The bar still seems to be attached near the headlight area. When I look up under the headlights there is fairly large white square clip. I can’t move this but. Does this mean I need to remove the headlights to get the front bar off? Any help would be greatly appreciated, as I can’t take it any more this bar needs to come off! Thanks guys…also does anyone know of a book that has this type of stuff in it. I got the tech manual but it is more for mechanics than a backyard tinkerer like me. Thanks heaps guys! :D
https://www.sau.com.au/forums/topic/84089-removing-the-front-bar-of-a-r33/
Hey mate, i have done this anumerous times now the first time is definately the hardest the best thing to do is get a long skinney flat hear screwdriver and gently pry the clip up while pulling on the front bar, easier if you get someone to give u a hand to hold the bar, do this on both sides and the bar should come off if you have all the bolts un done.
Is it eaiser just to unbolt the reo (2 bolds either side), and the bolts either side near the guards. The whole lot comes away.
I have not done it but I have recently had a new bar fitted and the group who did it took the whole lot off then unbolted the bar from the reo.
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
