Hi All,
I recently ordered a Stage 1 brake upgrade kit from Unique AutoSports for my R32 GTR (RRP $795). The kit consists of 324mm R33 GTR dba 4000 series rotors , callper adapters, cap bolts, and shnoor washers (what the hell does shnoor mean?).
It was only after ordering and paying for this kit that I've heard of brake pad overhang problems. I contacted Steve from dba to ask about this and he responded:
"A caliper is made to match a certain radius of the disc. When you raise a caliper by means of a bracket it changes the working radius of the caliper and sometimes the pad will hang over the O.D of the disc in the middle of the pad on the top edge. It can cause issues with noise and additional stress on the edge of the disc. I'm sure you can modify the pad if it happens."
Has anyone else experienced this problem , and if so, how difficult was it to modify the pad, and did this solve the problem?
https://www.sau.com.au/forums/topic/84126-brake-pad-overhang/
Hi All,
Hi, simple to fix, I haven't used the UAS kit but I have done plenty of rotor size upgrades over the years. Simply cut around 2mm from the top (radius) of the pad material with a hacksaw. Takes about 1 minute per pad.
The trick is to get the pad and lay it on the rotor so that the outside of pad radius lines up with the rotor. You will find that the pads is a tighter radius, so you can mark it with a pencil and then trim it with a hacksaw. You can also file/emery it, but that makes a dusty mess.
UAS should really sell the kit with pads that have a larger (outer) radius to suite the larger radius rotors.
:D cheers :D
There's a free tip for you, John :P
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
