  • Replies 46
50% is arguable, but yes with a Power FC particularly, you can easily overcome the issues caused by the factory GTS-T engine management when you have the typical exhaust/intercooler/pod type mods and want to run higher boost.
This is just one of the many benefits available when running the Power FC, and at the price they are available for currently, they are excellent value and bang for your buck!
I've been thinking about mods too actually, pretty used to the power now...which is sooner than I expected.
How is drivability effected? I use my car as an everyday car, so if it ends up drinking heaps more then I'm probably better off without it..
BTW from a newb, what are the minimum mods required to make the most of the Power FC?
Cheers
AF
A PowerFC is pretty flexible. You'd have to have done some serious mods to get to its limits, or be doing something pretty uncommon to find holes in its ability.
I find that most people tend to replace their PowerFC only when they need data logging or telemetry.....which pretty much means a well funded race team.
Well, basically I want to change the exhaust which is stock, put a cold air intake in and possibly fmic and high flow my turbo if the budget permits...then I want to do the interior :D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
