Hi,
This started a little over 3 months back. My first gear would get stuck and will not shift to 2nd no matter how hard I rev (can be as high as 6k!! and still no shift!). Only remedy is to stop the car, turn off everything, restart, then its all ok again. In the beginning it was about twice a week, then progressively got worst until once or twice a day. I took it to the Auto Tranny ppl and they could not help. I did self diagnostics and it came out ok (followed the service manual). Then funny thing, right after I took it to the Auto Tranny guys the second time, of which they did not do anything at all except fiddle with my interior electrical connections trying to find an OBD II port (Now I am sure the S13 do not have one!!). Since then, it was running all good for 2 months, never recurred again. And just 2 weeks ago, it started again...about once every 2-3 days. I am expecting it to get worst...
Any ideas what could be wrong or what I can do?
Apparently on the 200SX CA18DET AUTO, the ECU controls the transmission as well (???) cos' at the Tranny shop we could not find the TCU (Transmission Control Unit)..
Hope you guys can help out. Thanks!
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
