Virtually brand new TO4e Turbo-charger. This item has travelled around 1000kms and is in excellent condition. The majority of the turbo is spotless with just a minor amount of carbon present in the exhaust housing. This particular turbo was fitted to an internally standard RB25DET and produced 298rwkw on 18 psi of boost. Be quick and grab yourself a bargain folks.
ID plate on comp cover-type HKS, T3V band, part no. TO4E and serial number is AO7100152.
One the comp cover there is J84A cast onto it and 4 10 6 stamped into it above the ID plate.
On the rear of comp housing you have 4 numbers: 5327-5794, 5617, K27.015 and HJ.
The exhaust housing measures 60 mm on the outlet side, inlet ports times 2(split pulse) are 45mm by 29mm each.
On the outside of the casting the scroll is 75mm where it leaves the T3 flange and about 40 mm where it meets the wheel trim
For Sale due to upgrade
$950
WILL ACCEPT COD IF REQUIRED
https://www.sau.com.au/forums/topic/84170-t04e-turbo/
Guest
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
