  • Replies 47
pretty ignorant, if its 98RON, then it should be as good as the Mobil and BP stuff. I have noticed no differance in knock levels between Mobil or BP, but I tend to get less kms out of BP Ultimate
Chances are its probably comes out of the same refinery as either BP or Mobil
the SAFF on OG Road sells 100RON Racing Fuel
Im going to give it a try next time I go past a SAFF, the one I saw selling it was down near Holdens at Elizabeth
I think they take discount vouchers too.....
if your going to use the STAFF 98 ron fuel that im sure it should be ok if you got it tuned to take 98 ron fuel no matter what it comes from ie Staff/bp/mobil. But what is the point in using 100 ron fuel if you only use it once in a blue moon?
Yeah, the SAFF 98 should be no differant to the BP/Mobil fuel
100 Octane is good for track days etc where that bit of extra octane can be the differance in going home happy, or towing your car home because it had been detonating with the extra heat your car experiences at the track. It was pretty expensive though, at about $1.65 a litre I think (that was 8 months ago too)
I have used it once, and it was quite good
I think they are calling the SAFF stuff 'Boost 98' or seomthing like that
Interesting to hear people say "if it's 98 it should be just as good as the others"
Ask some questions of some people who have used optimax (not available in SA) and listen to the responses. Plenty will never use it again.
Also, I wouldn't buy fuel from a servo that didn't sell a lot of it. This high octane unleaded goes off, so if they aren't selling a lot and getting topped up frequently you might get a stale batch.
The moral of the story - always buy fuel from a busy servo.
A recent write up in a magazine found all 98ron fuels were 98, but the age of the fuel will make a difference. I think this is the big benefit with BP as they use fewer aromatics to produce 98ron, and hence it is less susceptible to the age problem.
Actually a lower sulfur content is better for your engine, cos it can form sulphuric acid and etch away in your combustion chamber when the engine is cold. It was one of the main contributors to cold start engine wear. Was reading that in a SAE paper a while back..
Edited by Busky2k
Yeah good mate. Yourself?
Oh yeah when I was surfing the SAFF website, seems this 98ROn stuff is 10% ethanol. Good for emmissions and the environment but could have unpredictable results in modified boosted cars like ours.
Edited by Busky2k
I am always looking for a positive, so another way of putting it is that the acid eats away at the combustion chamber (making it larger) and hence decompresses it allowing me to run more boost (and hence get more power without detonation). How much sulphur fuel will I need to get my RB25 up to an RB26?
The glass is always half full.
Thats good to hear, im going well.
In regards to the SAFF fuel, Im doubt their is many sa import owners with "hard" tuned cars though (correct me if im wrong).
There are always those who still haven't had a retune since Mik from Tilbrooks touched their cars (admitedly most of them dont run anymore)
Edited by 4door_Sleeper
Sorry "hard tuned" (before I edited it) meant cars with programmable ECUs that tuned to make more power than the stockie ECU. Ie leaner AFRs, more ign advance. Thus they are more succeptable to detonation from a shitty fuel. (being 'harder tuned' than factory if you get what i mean).
4door, your a crack up mate. :P In the real world, that means the clearances between your piston and bore open up due to wear. I think the rings suffered too IIRC.
Edited by Busky2k
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
