The only difference witht he R33 S2 is it uses 1 earth for both the signal and 12v feed.
Grab a multimeter and find out which one is which, its easy.
The z32 afm wiring guide I did has been corrupted, I upload a new uncorrupted version however the forum still corrupts it. :(
With regards to the plug I popped down to the local U-Pull It parts wreckers and grabbed a plug from a VL Commodore, they are the same as the Z32 plug.
https://www.sau.com.au/forums/topic/84179-tomei-z32-plugs/#findComment-1524289
From what I can see on the loom i have lying around, the R31 (aussie) is also the same 4pin square plug.. so yeah, doesn't matter if its off a VL or R31 (prolly not pintara though as they have a different afm from what i remember)
https://www.sau.com.au/forums/topic/84179-tomei-z32-plugs/#findComment-1525670
yes i use flux cored solder also and it works fine...flux pen thats like oxy brazing and having to dip the wire in the flux before welding...messy :P
Thanks for the offer crazy_boy but i should be fine on this one...just wasnt sure what the go was with the wires but i can use a multimeter to work out earth and 12v supply cheers.
https://www.sau.com.au/forums/topic/84179-tomei-z32-plugs/#findComment-1525710
The flux pen is nothing like oxy brazing. :P
The flux pen is a pen so you simply 'draw' on both wires, so its not messy.
Pool the solder on the soldering iron touch the wires and because the wires have the flux on them its like the wires suck the solder from the soldering iron.
I noticed the R31 afm plug was the same also.
https://www.sau.com.au/forums/topic/84179-tomei-z32-plugs/#findComment-1525818
I was refering to the difference in processes...not the actual flux for wire and flux for brazing...my bad again...i assumed you would understand it from my view...i really should explain things more clearly.
-like heating up job then wire and dipping wire in flux and then brazing
-applying your flux pen to the wire then pooling the solder and letting it attach itself to the flux coated wire. both manual processes
-while just pooling solder with flux in it and letting it attach to the wire. more simpler process...but each to their own!
https://www.sau.com.au/forums/topic/84179-tomei-z32-plugs/#findComment-1526077
This is the solder I use. It has a resin core? Is that the flux?
Solder
I had some other stuff that was a little thicker and didn't melt to well with my cool soldering iron. It was supposed to have flux in it.
I had problems with the solder staying on the soldering iron and not transfering to the wire. The wire would end up having its insulation melted as the only way to get the solder on to the wire was to heat the sucker up. Even then it was still difficult.
https://www.sau.com.au/forums/topic/84179-tomei-z32-plugs/#findComment-1526899
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
