anyone know where i can get a flush R33 boot lid from? (such as below)
only one i have found is the Do Luck one, and its about $600 + postage and painting... looking for something a tad cheaper.
cheers :rant:
Edited by mitchy_
https://www.sau.com.au/forums/topic/84185-r33-boot-lid/
Do you guys realise how heavy the stock boot lid is? When i took mine off to fit my stealth wing i was shocked by its weight. By welding/bogging up a stock boot lid to make it flat will just make it that much heavier - if you just want the looks then i guess you dont have a problem with that. But yeah, as others have mentioned a cf boot from someone like speedworks will save you time and problem but in return cost you alot of money.
https://www.sau.com.au/forums/topic/84185-r33-boot-lid/#findComment-1525078
the bootlid isnt all that heavy.. i found it a shitload lighter with the wing removed..
and if i did hack up a stock one, id cut the old skin off, foam it up, and fibreglass over it, would be nice and rattle-proof then too.
https://www.sau.com.au/forums/topic/84185-r33-boot-lid/#findComment-1525127
Has anyone found a drift wing that you can bolt onto the boot lid instead of glueing it on? I've seen a few 'glued on' drift wings and could see the glue inbetween the seams, wasn't too impressed. Plus I would like to be able to take it off if I felt like it.
"Games don't affect people. If Pacman affected us as kids, we'd all be running around in darkened rooms munching on pills and listening to repetitive music."
https://www.sau.com.au/forums/topic/84185-r33-boot-lid/#findComment-1548845
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
