My diff is starting to open wheel, and I am looking at my options. As the car already makes a lot more power than the standard diff was meant to handel, I was wondering if it is worthwhile fixing it, or replacing it with a GTR diff?
My questions are :
1. are they interchangable?
2. can I just change the center or should I also change the 1/2 shafts.
3. are r32 and r33 GTR diffs the same? (or do I have to find one from a 33)
4. are the GTR diffs any stronger (I would have thought so but I may be wrong)
Any advise sought, but I would love to here frome someone who has done this already. I realise I could go for an aftermarket diff, but the car isnt driven thet hard often enough for me to justify the $2000 (installed) price tags I have been given.
https://www.sau.com.au/forums/topic/84196-gtr-diff-in-a-gtst/
I can only answer question 4 for you...they are stronger..and good..I have a quote here that says .."so good are the stock 1.5 way GTR differentials that you would not change them for virtually any purpose, Plenty of cars have run 9 second passes on them which is a testament to how well they work". How ever I was thinking will it really work out that much cheaper than a new aftermarket one? Not too sure on the prices of the actuall diff but the labour might make it almost the same cost if it is somthing that hasnt been done too often before! Any way best of luck with it and let us know if it works out!
I believe they have a different spline in the centre, so will need to have the shafts as well as they are a six bolt fitting off the diff instead of five bolt in GTS25t.
I don't believe they are a 1.5 diff in the true sense but are a much stronger viscous diff. I could be wrong but mine does not drive like that. It will scrub up on tight turns in the car park.
I also believe the housings are different but centres interchangable.
I reckon you need an answer to q2 before you decide to replace the whole thing.
"2. can I just change the center or should I also change the 1/2 shafts."
Sorry I'm not sure if the 32 gtr one fits tho. When the centre in my 33 gave up I put a mechanical centre in.
I have been offered a GTR rear end for a few hundred dollars.
The $1100 Kaaz option is the price I was quoted for the center only, then I neeed to install it, plus bearings, plus plus, pluss (final price between 1500-2500 depending upon what they find) Hence the interest in a n R32 GTR diff option.
OK then, sounds like the GTR option is a good one. What I am left unsure of is if a GTR diff from an R32 (full set disk to disk), can  be grafted into my 33GTSt?
I don't see why it wouldn't, i put one straight into a 200SX, there was only one mounting bracket difference since you have a skyline it should go straight in :P
installing the gtr diff will be similar cost to installing the kaaz centre (maybe more hassel if tailshaft/driveshafts doesn't bolt up to the gtr housing)
if you don't want to crack open the diff housing, maybe look for a second hand 2 way (eg nismo, cusco, or kaaz) which comes with housing.
But seriously changing centres isn't very hard, main time consuming part of changing diff is removing / reinstalling the diff housing from the car.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
