My diff is starting to open wheel, and I am looking at my options. As the car already makes a lot more power than the standard diff was meant to handel, I was wondering if it is worthwhile fixing it, or replacing it with a GTR diff?
My questions are :
1. are they interchangable?
2. can I just change the center or should I also change the 1/2 shafts.
3. are r32 and r33 GTR diffs the same? (or do I have to find one from a 33)
4. are the GTR diffs any stronger (I would have thought so but I may be wrong)
Any advise sought, but I would love to here frome someone who has done this already. I realise I could go for an aftermarket diff, but the car isnt driven thet hard often enough for me to justify the $2000 (installed) price tags I have been given.
https://www.sau.com.au/forums/topic/84196-gtr-diff-in-a-gtst/
I can only answer question 4 for you...they are stronger..and good..I have a quote here that says .."so good are the stock 1.5 way GTR differentials that you would not change them for virtually any purpose, Plenty of cars have run 9 second passes on them which is a testament to how well they work". How ever I was thinking will it really work out that much cheaper than a new aftermarket one? Not too sure on the prices of the actuall diff but the labour might make it almost the same cost if it is somthing that hasnt been done too often before! Any way best of luck with it and let us know if it works out!
I believe they have a different spline in the centre, so will need to have the shafts as well as they are a six bolt fitting off the diff instead of five bolt in GTS25t.
I don't believe they are a 1.5 diff in the true sense but are a much stronger viscous diff. I could be wrong but mine does not drive like that. It will scrub up on tight turns in the car park.
I also believe the housings are different but centres interchangable.
I reckon you need an answer to q2 before you decide to replace the whole thing.
"2. can I just change the center or should I also change the 1/2 shafts."
Sorry I'm not sure if the 32 gtr one fits tho. When the centre in my 33 gave up I put a mechanical centre in.
I have been offered a GTR rear end for a few hundred dollars.
The $1100 Kaaz option is the price I was quoted for the center only, then I neeed to install it, plus bearings, plus plus, pluss (final price between 1500-2500 depending upon what they find) Hence the interest in a n R32 GTR diff option.
OK then, sounds like the GTR option is a good one. What I am left unsure of is if a GTR diff from an R32 (full set disk to disk), can  be grafted into my 33GTSt?
I don't see why it wouldn't, i put one straight into a 200SX, there was only one mounting bracket difference since you have a skyline it should go straight in :P
installing the gtr diff will be similar cost to installing the kaaz centre (maybe more hassel if tailshaft/driveshafts doesn't bolt up to the gtr housing)
if you don't want to crack open the diff housing, maybe look for a second hand 2 way (eg nismo, cusco, or kaaz) which comes with housing.
But seriously changing centres isn't very hard, main time consuming part of changing diff is removing / reinstalling the diff housing from the car.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
