stuffed ceramic turbo would be about the only real problem with them to look for, the 32 gtst is tuff as and cheap to fix if anything goes wrong.
thanks to the 15 year rule and volume on the market you'll be looking anywhere from about $12-$15 i reckon.
Firstly.
GUIDE TO BUYING A SKYLINE
Check this post out. EXTREMELY helpful. Print it out read it several hundred times (na, just jokin!) read it a few times and if you've found the skyline you're looking for take the guide with you to refer to. Pretty much everything you need to look for is in that guide.
Another tip from myself is look out for rust on the R32's. The most common places for rust are rear wheel arches, just under it or around it. As well as wheel arches open the boot and pull carpet up and look for rust there, look around the boot seals as well. Indication that water maybe leaking into the boot. Ask yourself why water is leaking, worn seal? bodgy accident damage etc. DON'T BE SCARED TO ASK QUESTIONS!!
Another common place for rust on 32's is the floor under front passen :( ger and driver passenger. Hard to spot it unless you take carpet up and have a look. Also look in the engine bay around firewall etc. Open the doors and look at the bottom seals along the body for rust. If its just surface rust, no worries cheap to fix and stop if you get to it quickly enough.
Um... apart from that, the usual steering wheel, shift knob & hand brake lever wear which are common for a car its age. Apart from that you should be good to go!! As the guide also says put it up on a hoist, check the underbody and get a compression test done on the engine.
I could go on with HEAPS more stuff but the link I have provided you pretty much covers the basics in which you need to check gearbox etc.
I hope ive been helpful to you mate and good luck!!
One final note as well, 15 year rule has been discontinued for sometime, BUT, some importers still have stock that was purchased PRIOR to 15 year cancellation. Check the import sites out because they still have some 15 year stock. Don't wait too long as it will go very quickly.
peace. :)
-trel
Cheers for you help, i bought an s13 with out researching first! :( ha ha so i am aware of most of these things, i was more looking for common problems. Like s13's commonly have stuff tye rod ends:P
I think i have found the one i am looking for, just trying to sell my car!
  • 4 weeks later...
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
