Skyline model = R32 GT-R
Wheel diameter = 18"
Wheel width = 9.5"
Wheel offset = +22
Tyre size = 255/35/18 all round
Modifications to fit = none!
they are sparco racing wheels with a nice bit of dish...just thought id add that
Edited by Turbz_13
Still nobody has answered this question. Can you fit R32 GTR rims on a R33 gtst??
Cheers
id also like to know this....atleast will they fit on rears? plus whats the widest tread you can fit on a r32 gtr rim?
to the above.. yes..
now for my new rims
Skyline model = R32 GTS-T lowered to guard 345mm front/rear
Wheel type = V35 standard rims (non track)
Wheel diameter = 17"
Wheel width =7.5" front/8" rear
Wheel offset =33(F), 30®
Tyre size = 215/55R17
Modifications to fit = front tyres scrub control arms.. requires lower profile tyres to fit fronts.
Ended up going for 235/45R17's for the fronts.. clearance is fine, however can scrub plastic guards on heavy bumps
Skyline model = BNR32
Wheel Brand = O.E.M R33 GT-R
Wheel diameter = 17
Wheel width = 9
Wheel offset = 30
Tyre size = 235/45
Modifications to fit = None (naturally)
These wheels give really good clearance around the brake callipers, for anyone looking to go up in brake rotor size without having to use adaptors.
Skyline model = SII R33 GTS-25t Sedan
Wheel Brand = Lenso GT-05
Wheel diameter = 18
Wheel width = 8(f), 8®
Wheel offset = +38
Tyre size = 225/40/R18, 235/40/R18 - Nankang NSII
Modifications to fit - Larger front rotors to increase space between caliper and spokes. Plus fill up that large gap between wheel and calipers :D.
These wheels will not fit over the front caliper without spacer or grinding the caliper. Ive gone to a 32GTR V-Spec disc (324mm x 30mm, a 28 mm increase in disc diameter) to clear the spokes.
Also i think people should be posting up brand and model of wheel so that others can see if their wheel of choice will fit over the front calipers.
cheers
Evil
Edited by EvilINGT
Hi guys i am looking at getting a set 19X10 racing hart cr wheels for my R33 GTR.
I wont the wheels to sit as close to the side guards as possible or even if they stick out just alittle, wondering if +20 is the offset i am looking for?
Thanks
Adam.
First of all, please forgive my ignorance. I am new to this site and found it to be a great Forum and has great people!
This is a great thread and i've just gone through to read all the pages. Lots of info in there. However, not many people have posted offsets on a R34 GTT. I've got a question as per the person posted before me. Can a 18x9.5 +30 wheel fit onto my R34 GTT seriesII? My car is stock with standard wheels and suspension. I am looking at changing my wheels to one of the BEE-R/Nismo LM types.
With this settings, will I have any clearance/rubbing problems? even with full turns?
Lastly, has anyone heard about Rota wheels and where to get them in Australia? Thank you all in advance! Keep it coming! Cheers,Michael
  • 3 weeks later...
model = Cefiro A31
Wheel Brand = Work meisters S1's
Wheel diameter = 17
Wheel width = 8(f), 9®
Wheel offset = +30(f), +35®
Tyre size = 215/45/R17, 235/45/R17 -
Modifications to fit - chop a tiny bit of the right hand plastic guard. The fronts stick out about 4 mm.
  • 4 weeks later...
I have asked this before and got a "probably not answer"
But will ask again to see if anyone has tried...an R32 GTSt with 17x9 +22 offset rims. Guards are rolled and car is not that low. Im thining even if i put narrow and lower profile rubber on them????? Say 225/40 front and 255/40 rears etc.
Or am i simply no chance. Unfortunately the rims are interstate so cant trial fit before buying
Skyline model = R32 gts-t 4dr
Wheel width = F:8 R:9
Wheel offset = +30 all round
Tyre size = 235/40/18 all round
Modifications to fit = none on the back, lipped the guards on the front
ROY:
you should fit them on the front. ive got about 35mm of clearence to the guard with 18x8 +30, and you need an extra 20mm to fit 17x9 +22. so with the steering wheel straight they should fit.
the rears will fit cos they will stick out 8mm more than mine and ive got about 20mm clearance from the guard with 235/40R18s.
if your lip is gone, then 255/40R17 should fit, if not stretch 235/45R17
and you want 225/45R17 for the front, not 225/40R17
Edited by salad
I'm looking at a set of 18x9.5" rims with a +12 offset will these fit with out and mods to fit (r32 GT-R)? I know the +12 offset is getting a bit boarderline for 9.5" wide rims
Can anyone confirm this?
I've got 18x9.5's with a +13 offset front and rear. The rears on mine don't seem to be a problem, and the fronts only lightly rub on one of the tabs for the guard liner when under heaps of load, or with more than 1 person in the car. A lot of that probably has to do with my suspension having HEAPS of travel, so with some stiff coilovers, the problems should disappear.
Incidently, tyres are 245/45/18's.
Skyline model = 1989 R32 GT-R
Wheel Brand = Work Emotion XT7
Wheel width = 9.5"
Wheel offset = 20
Tyre size = 245/40/18
Modifications to fit = None.
Car is quite low, as low as a set of super low springs if you had them. ( I have Teins)
Skyline model = 1996 R33 GT-R V-Spec
Wheel Brand = Work Emotion XD9
Wheel width = 10"
Wheel offset = +18
Tyre size = 265/35/18
They sure do fill out the guards now :banana:
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
