Skyline model = R32 GTST
Wheel diameter = 17"
Wheel width = 8" front 9" Rear
Wheel offset = +42 Front +42 Rear
Tyre size = 235/45/17 Front 235/45/17 Rear
Modifications to fit: front requires 5mm spacers to give enough spacing with 235's
Hi guys,
I'd like to know if I wanna get rims for my R32 gts-t in 17 inch with 8" front and 9" rear So, what offset should I get to make the rims sit right to the outside of the guard without rubbing? (will lowerring the car too)
any pics would be good
Cheers
Ford
Quick Question Guys.
I have been reading over this thread and it appears that the largest wheel size you can put on an R33 GTR with NO modifications are: 18 X 10 +18 or +20
I just want to confirm that you dont have any clearance issues as far as with turning or anything like that. 10" wide wheels would be perfect for my build as I need to help with traction, but I just want to make sure that I am not going to have any problems turning or anything along those lines as I will probably be getting into doing road racing as well.
Thanks a lot for the info and the help guys. I do greatly apprecaite it,
-Sayajin
Wheel diameter = 18"
Wheel width = 8.5" front 9.5" Rear
Wheel offset = +37
Tyre size = 225/45r18
Wheel type = Work meister s1
Modifications to fit = i have coil overs and no inner guards
Will these fit?????????
Skyline model = R33 GTST
wheel type= advan racing series 1 tri spoke
Wheel offset = +35 Front +35 Rear
Modifications to fit: none
i was looking at getting some 18s for the line but im not shore what offsets to go any help would be great im looking at 18x8.5 front and rear with tyres probly 235x40x18. car has been lowered nuthing stupid tho and still has standard brake calipers etc i would like to have the offsets so that the wheels are close to the edge of the gaurd cos it looks funny when wheels sit inside the gaurds heaps so any one who can tell me wat offsets to run would be great
wheel type= work VS KF
Wheel diameter = 18''
Wheel width = 8'' 9''
Wheel offset = +34 front, +38 rear
Tyre size =235/40/18 front, 265/40/18 rear
Modifications to fit = none to stock height (till i lower it, then it will be rolled & flaired)
Ok, teh beast is an R32 GTS4.
Front wheels: 18 x8, offset 29mm.
Rear wheels: 18x9, offest 35 mm.
Tyres F & R: 235/40/18.
No mods to fit. However, once the car is lowered and a camber correction kit fitted the rear guards will need lipping.
Could be run lowered with excessive camber ( was when I bought it ) but that's dumb anyway.
@ subie: You'll be f**ked on the rears, mate. Guards will need lipping at least, judging by my car.
Dunno about the fronts but don't like your chances. I intend to change to 18 x 8 all round.
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
