All these with around -2 camber
Skyline model = R32 GTS-t
Fronts:
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +30
Tyre size = 235/45
Modifications to fit = none really, lip sat a few mm out of the top of the stock guards, although with lower or weaker suspension they may have scraped a bit, also was only just missing the upper control arm, any lower offset or bigger tire and it probably would have started fouling.
Wheel width = 8.5"
Wheel offset = +30
Tyre size = 215
Modifications to fit = none, sits a few mm in on the stock guards
Wheel width = 8"
Wheel offset = +30
Tyre size = 235
Modifications to fit = none, sat inside the stock guards
Wheel width = 8.5"
Wheel offset = +15
Tyre size = 225
Modifications to fit = lip stuck out of stock guard by about 15mm, guard rolled and pulled about 5-10mm
Wheel width = 9"
Wheel offset = +16
Tyre size = 225/45, 235/45
Modifications to fit = sits out about 20mm from stock guard, no scrapage with 225's and running the -2 camber, probably would need some flaring if lower, had less camber and with the 235's.
Rear:
Wheel width = 9.5"
Wheel offset = +38
Tyre size = 255/45, 235/45, 225/45
Modifications to fit = lip stuck out of stock guards by about 5mm, with the 255 tires it needed the guard to be rolled, with 235 and 225 none needed
Wheel width = 9"
Wheel offset = +30
Tyre size = 235/45
Modifications to fit = lip sat out of stock gaurds by about 5-8mm, rolled guards as there was a bit of scrapage on stock guards
Wheel width = 9.5"
Wheel offset = +35
Tyre size = 235/45
Modifications to fit = as above there was minor scrapage so guards needed rolled.
Wheel width = 9"
Wheel offset = +38
Tyre size = 225/45
Modifications to fit = none, sat in the stock guard a few mm
Wheel width = 9.5"
Wheel offset = +30
Tyre size = 255/45
Modifications to fit = sat out from stock guard about 15mm, guard rolling as a minimum needed, maybe a bit of pulling or flaring for comfortable fit
Wheel width = 10"
Wheel offset = +22
Tyre size = 255/45
Modifications to fit = sat out about 30mm from stock guard, would need at least some flaring.
Wheel width = 9"
Wheel offset = +16
Tyre size = 215/45, 235/45
Modifications to fit = sits out about 25mm from stock guard, snuck under the 215/45's under with just a roll and running the -2 camber, would need at least some flaring with lower camber and 235's.
a few more but that'll do for now.
Have a bit of a question, looking at getting some 9.5' 17's for the rear and 8.5 17's for the front. Bothe with a + offset of 40
Now from this thread the rears and fronts should be ok offset wise. But when I measured the rear of the car yesterday, it looks like the rears will be something like .3cm to .5cm away from the hicas control arm, if I saw it correctly. Has anyone fitted 17's which are 9.5' wide on a 32 with hicas with that particular offset and had any issues?
Or nisskid did you have any issues? since it looks like you had 9.5's with a 38 offset on your 4dr 32. Did it have hicas?
+40 on a 17x8.5" wheel will not fit on the front, the closest ive got my front wheel to the upper control arm was 17x9" +30which was only a few mm away from touching the upper control arm, which is about the equivalent (inner clearance wise) of a 17x8.5 +36. now u could try but id say u will foul on the upper control arm, especially if u run anything above a 225/45 on it.
on the rear ur tie rod becomes the issue, and it will start to foul on a 17" wheel at around 9.5" +40 depending on design and a few other things. closest ive got to the tie rod was my 9.5 +38's which were only a few mm away from fouling on it. btw when i say tie rod im talking about what u were referring to as the HICAS.
if u want to run a 17x9.5 on the rear ur best bet is with going for a offset around +35, this will mean u might have to roll ur guards, but its better than it fouling on the tie rod. as for the front ull need to go for around a +35 offset if u want to run 17x8.5's on the front, personally id go for a +30 offset as it fills out the guard nicer and most likely still wont rub on ur gaurds (depending on ride height, camber, tire tread/profile etc etc)
Does anyone have Koya Drift Teks on their R34 or even R33.
I'm looking at 17x8 (front) +30 & 17x9 +35 (rear)..
Will these fit and also I'm a bit worried about clearing the calipers too..
Edited by so_tred
are u sure its 17x8 +30? pretty sure drift teks only came in a 17x8 +34. anyways, in relation to ur guards u wont have any issues, rears will come up and sit near the guards but u shouldnt have any scrubbing issues, the fronts will sit in a fair way. as far as brake clearance the drift teks use a design which is usually pretty good for clearing big brakes, i know they clear r32 gts-t m-spec brakes which i believe are pretty similar to r33 brakes, also i think i remember someone running them on their GTR which didnt use spacers i believe.
Yeah, I thought they only came in +34 too, but I'm thinking now they might come in a couple of different offsets cause another friend has +38 on either 8" or 9" (can't remember which one..)
anyway, the guy I'm buying them off is gonna put them on right then and there and if there's any issues I get a refund so hopefully should be all good..
If an R34 GTR was slightly lowered would 19x10, offset+15, Rays RE30 (L2 type) rims with 275/30 tyres fit without any rolling/lipping needed to the guards? Or would some minor work need to be done?
Regards,
Im having alot of issues with wheel choice!
Iv come down to a set of 17x8 and 17x9 Wedsport SA-90's for my R33 S2 25-t.
They dont come in alot of offsets and i was wondering if anyone could advise me on what to get?
I was thinking +35 for the rear, and +25 for the front.. does anyone know if this will actually work?
Would i be better off going for +35 on the front too or whaaa?
in 9" you can only get +35 and +20.. so limited for choice there!
and 8" you can get +25, +35 and +42.. hmmm
  • 3 weeks later...
Can some1 pls tell me the standard offset for my R32 GTS (non turbo, 1989, 4 stud):
the tyres i currently have on it are 205/60 R15 and im hoping to go 235/40 R18
but i need to know my offset so i can confirm they will fit & not waste my time, thanks in advance.
just an FYI i really dislike the fact they chose 4 stud when designing this model of skyline, pain in the friggin ass!!!
Fit like a dream on my 32GTR with slightly lowered suspension, no guard rolling was done and no rubbing at full lock either.
Rims = 5Zigen Pro Racer GN+ (Try to stay away from 21mm lugs, you will scratch the inside of the rim :ermm: )
Wheel diameter = 18"
Wheel width = 9.5"
Wheel offset = +22
Tyre size = 245/40 (255's will fit)
Thats all round as well.
Hey guys, are any of you real familiar with the ER34 GTT 2 door wheel specs?
I'm looking to buy the Racing Hart CXR's..
Front 19 x 8.5 +35 (I want them streched so I'm guessing 225's?)
Rear 19 x 9.5 +38 (same as above so I'm guessing 255's?)
Is it possible to go 10 or 10.5 on the rear?
I have no idea what else needs to be done so far as lowering and/or rolling as well.
Many thanks from S.Korea!
1997 R33 GTST with some R34GTR Rims
Standard suspension as far as I know.
R34GTR Wheel:
Wheel width = 9"
Wheel offset = +30?
Tyre size = 265/35/18 all round
Does not rub at front with 265s on full lock but I removed the plastic card crap that stops mud/rocks flinging forward towards the front bar. The rear tyres are hitting the guard over dips in the road.. so I am going to roll the guards :P
R34GTR Wheel:
Wheel width = 9"
Wheel offset = +30?
Does not rub at front with 265s on full lock but I removed the plastic card crap that stops mud/rocks flinging forward towards the front bar. The rear tyres are hitting the guard over dips in the road.. so I am going to roll the guards :)
I want that so bad! But shit peopel ask a premium for 34GTR wheels!
Looks good man. Maybe add a bit of camber th the rear, help with clearance?
the question is, do u really need to go 10 or 10.5? depends what tire u want to run, but theres no point trying to fit a bigger wheel under if ur not going to use the extra width. u should be able to get a 10" wheel under, and probably a 10.5" but unfortunately i dont know what the inner clearance is like for the 34 gtt, to fit a 10.5" where u wanted the 9.5's to sit ur probably going to go up near the +50 offset mark, or if ur willing to give ur guards a roll and stretch the tire a bit u could go for a +35ish offset, either way ur not going to have much inner clearance for anything that u might knock under there.
standard offset is around +45 i beleive and the width is around 6"
if u wanted to go 235 u should go at least a +30 offset imo, otherwise ur pushing it close to the upper control arm in the 32.
I think i've posted this link about 100 times or so in this section. But it's a very useful link.
http://marksink.com/tire_wheel_offset/offset.html
Use this to enter the offset and width of you current wheels, then input offsets of wheels you will like to buy and it'll tell you how far it'll stick out compared to your old rims, and how much clearance you'll have with the strut housing.
(maybe sk you should add this to the top post)
hi everybody,
i need great help here,i recently bought some wheels off Z33 and trying to fit them to a r33 series II,ive heard that wheels are 350z touring wheels.i tried to fit them into my car and it was ok when its on the jack and when i droped the jack the uper arm(gusess technically right) touches the tyre and cant roll the tyre.i havent lowered the car either.heard that this is something do with camber.ill mention my cars and tyre details below please advise me regarding this
350Z 18'' touring mag wheels with 225/40/18 tyres
http://ppgmedia.buysell.com/ppgphotos/2007...915-display.jpg
R33 GTST with standard suspension
Reagards
melbourne-express
More detail on the rims would be useful (picture is not) but according to:
http://www.350z-tech.com/zwiki/350Z_OEM_Wheel_Specifications
the dimensions are:
Offset: +30mm
According to another post on this forum, stock wheels on 33GTST are:
Offset: +40mm
Finally, according to the link you posted, based on these dimensions:
The clearance from stut housing to the inside of the wheel will be 9mm LESS
The outside edge of the wheel will EXTEND an extra 29mm
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
