Yeah it does. You can have bigger than 18in. They will have to be skinny and sit well into the guards.
I wasnt after a rough answer though id like to know what i can fit with stock gaurds... wat offset and width in an 18, what offset and width in a 19. not just "you can have big if you get skinny"
well atm ive got 18x8 +38 and 18x9 +38 fronts are much more sunken then the rears.
i've been told 18x8.5 +35 and 18x9.5+35 will be pretty much in line with guards and should fit without guard work
so i guess anything from +30 - +40 should be fine with the widths of 8-8.5 front and 9-9.5 rears.
i'm no expert but this is what ive found just searching around
so im assuming i couldnt get anything over an 18"
i was answering this, i was explaining that you can go over 18" and what ud have to do to go over 18"
if u'd read what i and many others have posted ud realise it isnt as simple as us telling u an exact offset and width, this is what im trying to explain. if you want to know what other people have used and got away with then read the rest of the thread, that is what it's for.
  • 3 weeks later...
hey all,
been approached by a friend to buy his rims..
SSR PROFESSORS,
18 x 9 +26 (F)
18 x 10.5 + 26 ®
what are the chances of these fitting on my R33 II gtst with a mild flare?
appreciate a reply on this as im rather keen on buying these wheels
cheers
I have 18 x 9.5 +27 for the rear and trial fitting suggested that they would be ~12-15mm outside the standard guard. I think those will be an extra 1/2" further out of the stock guards unless you are running an incredible amount of camber.
Edited by pkmike
hey i dont suppose you have any photos of these on the car from the rear so i can see how much they protude
hey all,
SSR PROFESSORS,
18 x 9 +26 (F)
18 x 10.5 + 26 ®
cheers
hey mate fronts are easy, rears are a bit harder, can be done with a stretched tyre and at least a guard roll, maybe a flare. put simply, u can make them fit.
THIS WAS THE KIND OF ANSWER I WAS AFTER!! HAHAHA THANK YOU NISSKID YOUR A CHAMPION.
but on a serious note, like i said i am prepared to go a mild flare if necessary, just thought i would post to double check.
thanks again
  • 4 weeks later...
thanks again
I purchased some 18x9.5 with +20 offset (all round) for my 33 gtst knowing they wouldnt fit, so I made them fit.
With a bit of a "mild flare" they now sit nicley on the car with no rubbing.
Need some help here..Ive got a R34 Sedan and im about to buy a set of wheel. The size is 18 x 10 + 18.. My question is can they fit in my car??? Do i need to roll the guard or spacer or something??? The reason for buying those size wheel is because i want to go wide body.. THX
u will need to at least roll ur guards and u will need to stretch tyres on them, at least a 235/40.
this is a 18x10 +18 on a R34 sedan:
http://www.skylinesaustralia.com/forums/in...t&id=147242
http://lh4.ggpht.com/howie.ly/SBQt-Lt7e3I/...00/DSC08934.JPG
its hard to tell when ur playing with fairly tight tolerances like we are here, expect the wheels to stick out a decent way, but the tyres will stretch in nicely and hopefully clear. but it will depend on ur suspension and camber.
Skyline model = R32 GTS-t
Wheel diameter = 17"
Wheel width = 9f 10r
Wheel offset = +15f +25r
Tyre size = 225/45f 245/40
Modifications to fit = We'll see when they get here :wave: Bring on the fender roller.
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
