Yeah it does. You can have bigger than 18in. They will have to be skinny and sit well into the guards.
I wasnt after a rough answer though id like to know what i can fit with stock gaurds... wat offset and width in an 18, what offset and width in a 19. not just "you can have big if you get skinny"
well atm ive got 18x8 +38 and 18x9 +38 fronts are much more sunken then the rears.
i've been told 18x8.5 +35 and 18x9.5+35 will be pretty much in line with guards and should fit without guard work
so i guess anything from +30 - +40 should be fine with the widths of 8-8.5 front and 9-9.5 rears.
i'm no expert but this is what ive found just searching around
so im assuming i couldnt get anything over an 18"
i was answering this, i was explaining that you can go over 18" and what ud have to do to go over 18"
if u'd read what i and many others have posted ud realise it isnt as simple as us telling u an exact offset and width, this is what im trying to explain. if you want to know what other people have used and got away with then read the rest of the thread, that is what it's for.
  • 3 weeks later...
hey all,
been approached by a friend to buy his rims..
SSR PROFESSORS,
18 x 9 +26 (F)
18 x 10.5 + 26 ®
what are the chances of these fitting on my R33 II gtst with a mild flare?
appreciate a reply on this as im rather keen on buying these wheels
cheers
I have 18 x 9.5 +27 for the rear and trial fitting suggested that they would be ~12-15mm outside the standard guard. I think those will be an extra 1/2" further out of the stock guards unless you are running an incredible amount of camber.
Edited by pkmike
hey i dont suppose you have any photos of these on the car from the rear so i can see how much they protude
hey all,
SSR PROFESSORS,
18 x 9 +26 (F)
18 x 10.5 + 26 ®
cheers
hey mate fronts are easy, rears are a bit harder, can be done with a stretched tyre and at least a guard roll, maybe a flare. put simply, u can make them fit.
THIS WAS THE KIND OF ANSWER I WAS AFTER!! HAHAHA THANK YOU NISSKID YOUR A CHAMPION.
but on a serious note, like i said i am prepared to go a mild flare if necessary, just thought i would post to double check.
thanks again
  • 4 weeks later...
thanks again
I purchased some 18x9.5 with +20 offset (all round) for my 33 gtst knowing they wouldnt fit, so I made them fit.
With a bit of a "mild flare" they now sit nicley on the car with no rubbing.
Need some help here..Ive got a R34 Sedan and im about to buy a set of wheel. The size is 18 x 10 + 18.. My question is can they fit in my car??? Do i need to roll the guard or spacer or something??? The reason for buying those size wheel is because i want to go wide body.. THX
u will need to at least roll ur guards and u will need to stretch tyres on them, at least a 235/40.
this is a 18x10 +18 on a R34 sedan:
http://www.skylinesaustralia.com/forums/in...t&id=147242
http://lh4.ggpht.com/howie.ly/SBQt-Lt7e3I/...00/DSC08934.JPG
its hard to tell when ur playing with fairly tight tolerances like we are here, expect the wheels to stick out a decent way, but the tyres will stretch in nicely and hopefully clear. but it will depend on ur suspension and camber.
Skyline model = R32 GTS-t
Wheel diameter = 17"
Wheel width = 9f 10r
Wheel offset = +15f +25r
Tyre size = 225/45f 245/40
Modifications to fit = We'll see when they get here :wave: Bring on the fender roller.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
