Hi all,
Putting the finishing touches on an order for new rims. The supplier has recommended the following.
18x8.5 +32 and 18x9.5 +38
Cars an R33 GTST S1
Can anyone confirm if there will be any issues with this?
Hi all,
Cars an R33 GTST S1
they will be fine
Hey All,
Here is my new set up on my new car.
Skyline model = A31 Cefiro
Wheel diameter = 18" Do-Luck Double Six rims :down:
Wheel width = 9.5"
Wheel offset = +15
Tyre size = Front 225/40/18 Rear 235/40/18
Modifications to fit = Flared/lipped guards approx. 20mm front and rear with 3.5 degree's front camber and 3 degree's rear.
Cheers
Phill
Edited by phillb
Skyline model = r32 4 door
Wheel diameter = 17 x 9
Offset = +25
Tyre size = Front 215/45/17 Rear 235/45/17
Modifications to fit = lipped rear, wider front guards... :D
Thinkin bout putting 20mm spacers on the front...could work, might be a little close to guards though?
Tried 25mm ones and are way too close to front bar and guard, looks cool but scared to crack more fibreglass!
will try 20mm ones soon...
Anyone run r33 gtr rims on a 32 with spacers? if so what size spacers on front and rear? Rear would be minimal size im guessing...
Cheers
Joey.
Skyline model = 1993 R32 GTR
Wheel diameter = 18" (Work XD9 Rims)
Wheel width = 4 x 10"
Wheel offset = +18
Tyre size = 4 x 275/35/ZR18 Semi Slicks (Not fitted in pics yet)
Modifications to fit = Just One, I lipped the rear arches. Also you need to make sure you buy the work hub rings overwise the wheels will be supported by the studs (not good) instead of the hub (good). My car is lowered so for the first few weeks it slightly rubbed against the front plastic wheel arch guide. No rubbing now.
Skyline model = 1996 R33 gtst
Wheel width = 2 x 9" and 2 x 10"
Wheel offset = +30 and +38 by recommendation, should have got a better offset
Tyre size = 2 x 235/40/18 and 2 x 225/40/18
Modifications to fit = currently fitted with no modifications at all.
Getting 20mm front and rear spacers and guards rolled tomorrow
Edited by blags
Skyline model = R32 gtst
Wheel diameter = 17" Buddyclub P1's
Wheel width = 9"
Wheel offset = +17
Tyre size = 215/45/17 front and 235/45/17 rear
Modifications to fit = 2.5 deg camber front 3 deg camber rear (too much havent got rear camber arms yet)
tucked in front lip a little will have to roll rear guards once take camber out but not by much
surprised the fit so well, though they would stick out way further
Skyline Model = 2000 R34 GT-R
Wheel Diameter = 18" (ADVAN Racing RG1)
Wheel Width = 9.5"
Wheel Offset = +12
Tyre Size = 245/40/18 but will replace with 255/40/18 I think.
Modifications to fit = None necessary but car's been lowered via Tanabe Springs 20mm
Tyres are still 7mm within the guards at front
Tyres are still 15mm within the guards at rear
If interested, you can PM me with E-Mail Address for pics
thought id finally post a picture, 20mm spacers on rear, nothing on front atm
Skyline Model = 1996 R33 GTST
Wheel Diameter = 18" (R34 GTR)
Wheel Width = 9"
Wheel Offset = +30
Tyre Size = 235/40/18
Modifications to fit = None. fronts clear the suspension arms etc by a whisker, no guard issues at all
These are Terry's old wheels (see 2 posts above lol). Cheers Terry :)
^will need to know offsets but since theyre off a r32 gtst it should fit.
any pics of them on the car?
heres the link here for the wheels http://www.skylinesaustralia.com/forums/18...ee-t267980.html
thanks for the help.......
That looks nuts Nisskid. Love it!
I have a 32 GTSt. Guards are rolled and pumped a bit.
I have Advan RS 18x9 +22 with 235/40/18 street tyres. They scrub a little but not too much.
For the track I use R33 GTR wheels (17x9 +30) with 235/45/17 semi's. No scrubbing at all when at the track.
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
    • Which I agree with. I don't want or need a high hp straight line car, I want it to be fun on the road and nothing more. Hence why I said my max power goal will be around 500 crank. The few times I drove the car last year I didn't even use high boost and it was already quick enough for me, should have been around 380-400 crank I think (2860-5s at 1-1.1bar).
