That looks nuts Nisskid. Love it!
I have a 32 GTSt. Guards are rolled and pumped a bit.
I have Advan RS 18x9 +22 with 235/40/18 street tyres. They scrub a little but not too much.
For the track I use R33 GTR wheels (17x9 +30) with 235/45/17 semi's. No scrubbing at all when at the track.
f**king love it, very tough :P
if guard mods dont worry u, go the -4 and modify the guards to fit.
depends what tyre u wanna run tho, personally i think 8" is too thin for the stretch fitment as to stretch a tyre properly u need to go into the 100's like a 195 or 185, u can get away with 205's, but even then i think they are a bit thin if ur wanting to go fast. if its just a daily, or a street skidder, then the 205 will be fine.
Skyline model = HR31 Passage GT
Wheel diameter = 17"
Wheel width = 9" (front and rear)
Wheel offset = +15
Tyre size = 235/45R17
Modifications to fit = front guards rolled
could do with a ~15mm spacer on the rear.
Hey nisskid/SAU
im looking at a set of rims for my gts-t
Fronts are 17 x 8.5 +30
Rears are 17 x 9 +28,
i already have tires
235/45/17
i have height adjustable coils but its lot very low at the moment. also stock guards
how is it going to look? major issues?
ive read the whole thread but couldnt find a combo that matched.
Thanks guys?
Hey nisskid/SAU
235/45/17
Thanks guys?
17x9 +30 and 17x8 +30 both with 235/45's (closest ive got)
rear:
this is a close up of a 17x9 +30 on the front, will be fairly similar to a 17x8.5 +30
your guards may need a roll depending on alignment and suspension. mine was very borderline at the rear with stock arms (fair bit of camber). front i had no issues with, but that was because my suspension never compressed enough to really push the tyres into the guard. so i would try them on, and see if u can get away with them, if not get ur guards rolled and ull have plenty of clearance.
can sumbody please confirm that 19x10.5 +9 Volk GTC face 1's will fit on a r33 GTR with standard brembo brakes.
Also what size tyres will i need
Edited by UWISSH!
  • 4 weeks later...
Skyline Model = r32 2 door
Wheel diameter = 17
Wheel width = 9
Wheel offset = +22
Tyre size = 235 front 255 rear
Modifications to fit = role heck out of guards. mainly because front of car is so low and rear tyres are too wide
hey guys been reading through this
need help
from what i gather (have a r34 gtt 2 door)
if im after 18s and want to avoid modifications, safer to go with 18 x 8s ? rather than say 18 x 8.5 or 18 x 9.5
will 18 x 8s also allow me a lower offset? from what i gather this would be the case? and this would mean a deeper dish effect? would this look good?
correct me if im wrong
also atm my car rides high at stock height, if i get rims i'd lower it a bit... does this help or detract?
cheers!
dish comes from distance between disk, and the outside of the barrel, this same distance determines the wheels clearance from the gaurd. if u just want clearance, go 6" wide with +40 offset. my point being u need to provide us with a bit more details, do u want the wheels to sit up near the guard? do u want wide tyres? etc etc
after speaking to a couple ppl, i've changed my mind, i am willing to roll the guards now
if i did 18 x 8.5 front and 18 x 9.5 back
would this fit on my car and with wat sort of offset, i was looking at +15 or +22 ?
regards to tyres i don't have too much knowledge on tyres atm but from what i've read here for the tyres im after im thinking 255/35/18 for front and for back 265/35/18
would this be a nice look withou being too bumpy a ride?
Edited by vudoo
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
