and if u thrash or see some track, then more often than that. i try to get an alignment at least once every few months, and rarely is it still within spec when it gets on the aligner each time.
True. Bouncing of ripple strips can do that :thumbsup: . Also digital alignments are hardly ever the same as each other.
hey pplz
gonna grab some rims for gf (they're gram lights 57 accelerate)
for her 34gtt - specs are : 18x8.5+33 (all around)
reckon they will fit??
I was unsure on the 8.5 on the fronts but someone mentioned if i stick to 235 fronts for the tyres then it should be ok?
Hey Guys,
I got a 93 R32 GTS-t
Looking to get some 17*7 +40mm for the front and 17*9 +35mm for the rear. Will i have to do fender rolling for the rear or front to get them to fit. Im trying to avoid this. Is there anyway that i can just run a smaller tire?
Hey Guys,
why the hell would u want that? fronts will come bloody close to fouling with 225/45's, rears will fit fine with 235/45's. will look like shit however due to the size/offset difference, rears will be around flush, fronts will be sunken A LOT
hey pplz
they will be fine.
ahk interesting, i get mine done at the same place every time, u mean from alignment to alignment, or from alignment machine to another alignment machine?
machine to machine. I'll only be going to one place now.
oh nisskid i need your wisdom!
my rims for the rear have arrived and i now am looking for a pair for the front to match the rears!
the rears are 18x10+18 with 235/40
this should stick out a little but i dont mind a little mexicana
but i'm not too sure how to get the right front fitment to match the rears!
what would you recommend? 18x9 +10?
btw this is for a r33 lowered on unknown tein coilovers
mismatched will be fine, especially if u have tough fitment. a lot of the yanks run mismatched for the same reasons, simply because it's easier to buy 2 2nd hand pairs at separate specs to suit you, than find a full set at perfect sepcs.
Hi Nisskid,
I found the rims I wanted and bought them. I may have to run a spacer on the front though to get the look I want.
I got 18x9 +38 with a 235/40 for the rears, and 17x8 +38 with a 225/45 for the fronts.
From what I've read these should be ok.
Hi Nisskid,
R32 I assume.
Should be fine.
oh and a quick question nothing wrong with running 17s for front and 18s for rear?
since i dont have unlimited funds i think it would be ideal to get maybe a set of 17x9s and run one pair on the fronts for daily/track
and the other pair for rears for drifting
Hi Nisskid,
yeh front will be close to the UCA, bloody close, generally i say 235/45 with a +30 offset is the furthest in id go, 225/45 will protrude 5mm less in, and about 4mm lower, but u have 8mm more offset pulling the tyre in further. so it will definitely be close, and probably come down to the tyre model and individual car as to whether it actually scrubs or not, but nothing a spacer a few mm thick cant fix.
my bet is that it will clear, but no guarantees on that one.
yeh thats fine.
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
